[AG-TECH] FC2 Install trouble
Douglas Kosovic
douglask at itee.uq.edu.au
Wed Jul 28 20:07:40 CDT 2004
> The globus.sh file should set the GLOBUS_LOCATION env var for you, and
> then source GLOBUS_LOCATION/etc/globus-user-env.sh, which sets
> LD_LIBRARY_PATH as Fred mentioned.
> So you should get this state in new shells after installing the package.
> If you run the software in a shell created before the install, you'll
> encounter problems like Mike did here.
This reminded me of a bug report I was received with the AGTk 2.12 Fedora
RPMs I did previously. Some people were resetting LD_LIBRARY_PATH in their
login script and therefore not finding the required globus-accessgrid shared
libraries.
The solution was to add the following lines to the globus-accessgrid RPM
spec file:
%post
/sbin/ldconfig
%postun
/sbin/ldconfig
Then build a new globus-accessgrid RPM file, so I might do the same with
this new version..
Doug
