[AG-TECH] FC2 Install trouble
Thomas D. Uram
turam at mcs.anl.gov
Wed Jul 28 14:50:47 CDT 2004
The globus.sh file should set the GLOBUS_LOCATION env var for you, and
then source GLOBUS_LOCATION/etc/globus-user-env.sh, which sets
LD_LIBRARY_PATH as Fred mentioned.
So you should get this state in new shells after installing the package.
If you run the software in a shell created before the install, you'll
encounter problems like Mike did here.
Tom
Fred Dech wrote:
> Michael.
> /etc/profile.d/.
> should have a couple new or updated files in it:
> -rwxr-xr-x 1 root root 110 Jul 28 11:37 globus.sh*
> -rwxr-xr-x 1 root root 101 Jul 28 11:37 globus.csh*
> a new shell bash or csh will source one of these and set some env vars:
> GLOBUS_LOCATION=/usr/lib/globus
> it also creates the following if they don't exist:
> LIBPATH=/usr/lib/globus/lib:/usr/lib:/lib
> SHLIB_PATH=/usr/lib/globus/lib
> SASL_PATH=/usr/lib/globus/lib/sasl
> GLOBUS_PATH=/usr/lib/globus
> you should also add /usr/lib/globus/lib to your LD_LIBRARY_PATH.
> --fred
> On Wed, Jul 28, 2004 at 01:05PM, Michael Miller said:
>>I'm having trouble installing on an IBM laptop with FC2.
>>Here's what I've done so far:
>>Installed FC2
>>Installed AccessGrid according to instructions here:
>> http://www.itee.uq.edu.au/~agn/ag_fedora/
>> I will do the following:
>> [install: AccessGrid 2.2-Snapshot_20040728.i386]
>> I will install/upgrade these to satisfy the dependencies:
>> [deps: xawtv 3.88-6.i386]
>> [deps: globus-accessgrid 2.4-2.i386]
>> [deps: wxPythonGTK-py2.3 2.5.1.5-1.i386]
>> Is this ok [y/N]: y
>> Downloading Packages
>> Getting xawtv-3.88-6.i386.rpm
>> xawtv-3.88-6.i386.rpm 100%
>>|=========================| 1.1 MB 00:04
>> Getting AccessGrid-2.2-Snapshot_20040728.i386.rpm
>>100% |=========================| 17 MB 01:01
>> Getting globus-accessgrid-2.4-2.i386.rpm
>>100% |=========================| 2.5 MB 00:08
>> Getting wxPythonGTK-py2.3-2.5.1.5-1.i386.rpm
>>100% |=========================| 11 MB 00:37
>> Running test transaction:
>> Test transaction complete, Success!
>> wxPythonGTK-py2.3 100 % done 1/4
>> globus-accessgrid 100 % done 2/4
>> xawtv 100 % done 3/4
>> AccessGrid 100 % done 4/4
>> DEBUG:ProxyGen:Using GT24 proxy code
>> Compiling Access Grid Python modules.... Done
>> Installed: AccessGrid 2.2-Snapshot_20040728.i386
>> Dep Installed: xawtv 3.88-6.i386 globus-accessgrid
>> 2.4-2.i386
>> Transaction(s) Complete
>>copied my cert to the machine with scp
>>And now I get this:
>>[mimiller at copland mimiller]$VenueClient.py -d --personalNode
>>Traceback (most recent call last):
>> File "/usr/bin/VenueClient.py", line 28, in ?
>> from AccessGrid.Toolkit import WXGUIApplication
>> File
>>"/sandbox/packaging/dist-20040728_180416/lib/python2.3/site-packages/AccessGrid/Toolkit.py",
>>line 22, in ?
>> File
>>"/sandbox/packaging/dist-20040728_180416/lib/python2.3/site-packages/AccessGrid/Security/CertificateManager.py",
>>line 53, in ?
>> File
>>"/sandbox/packaging/dist-20040728_180416/lib/python2.3/site-packages/AccessGrid/Utilities.py",
>>line 35, in ?
>> File
>>"/sandbox/packaging/dist-20040728_180416/lib/python2.3/site-packages/AccessGrid/Platform/__init__.py",
>>line 59, in ?
>> File
>>"/sandbox/packaging/dist-20040728_180416/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
>>line 22, in ?
>> File
>>"/sandbox/packaging/dist-20040728_180416/lib/python2.3/site-packages/pyGlobus/security.py",
>>line 11, in ?
>>ImportError: libglobus_gss_assist_gcc32pthr.so.0: cannot open shared
>>object file: No such file or directory
>>Let me know what I need to do...
>>Michael Miller
>>NCSA
>>Thanx,
>>Michael Miller
>>System Engineer
>>Visualization Technology Support
>>Computing and Data Management
>>National Center for Supercomputing Applications
>>University of Illinois - UC
>>217-649-0747
>>"If you're clear in your vision and trust the people in your team with
>>clear objectives, they will invariably do their best to achieve everything
>>desired, and usually deliver everything you could have hoped for and even
>>more." -Paul Debevec
