[AG-TECH] Graceful detection of proxy expiration in Shared Apps
Randy Groves
randy.groves at boeing.com
Thu Jul 22 13:11:26 CDT 2004
I don't know yet, since I'm still on the edges of this, whether there is a
routine that can be accessed, or if this is built into the Shared App
Client, but I was hit with a shared application that was trying to execute
across the boundary of a proxy expiration. The Venue Client didn't show
any problems (that is, until I tried to access the venue again, by hitting
'go'), but the app was dying with no obvious errors (the python command
window would pop up, spit out a message quickly, then die). When I ran the
app with a pointer to the app url in a command window, I find an error message:
C:\Documents and Settings\grovesr\Application
Data\AccessGrid\SharedApplications
\Immersaview_Launcher>immersaviewlauncher.py -a
https://venues.rt.cs.boeing.com:
8000/104
Traceback (most recent call last):
File "C:\Documents and Settings\grovesr\Application
ications\Immersaview_Launcher\ImmersaviewLauncher.py", line 900, in ?
il = ImmersaviewLauncher( appURL )
ications\Immersaview_Launcher\ImmersaviewLauncher.py", line 692, in __init__
(self.publicId, self.privateId) = self.__appProxy.Join()
File
"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\AGGSISOAP.py",
line 3660, in __call__
return self.__r_call(*args, **kw)
File
line 3680, in __r_call
self.__hd, self.__ma)
File
line 3580, in __call
config = self.config)
File
"C:\Python22\Lib\site-packages\AccessGrid\hosting\pyGlobus\Client.py", li
ne 188, in call
r.endheaders()
File "C:\Python22\lib\httplib.py", line 695, in endheaders
self._send_output()
File "C:\Python22\lib\httplib.py", line 581, in _send_output
self.send(msg)
File "C:\Python22\lib\httplib.py", line 548, in send
self.connect()
File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 1084, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python22\Lib\site-packages\pyGlobus\io.py", line 663, in connect
raise ex
pyGlobus.io.GSITCPSocketException: no credentials:
Credentials Expiredproxy expired: run grid-proxy-init or wgpi first
File=C:\DOCUME~1\grovesr\LOCALS~1\Temp\proxy
Function:proxy_init_cred
18:10:13: Debug: e:\projects\wx\src\msw\app.cpp(439): 'UnregisterClass(canvas)'
failed with error 0x00000584 (class still has open windows.).
This is a 2.1.2 shareed app and like I said - perhaps there is a routine to
use here to check on invocation and perhaps the new shared app client does
this more gracefully. But if not ...
-randy
