[AG-TECH] Port parameter values for VideoService
Michael Braitmaier
braitmaier at hlrs.de
Mon Jul 19 03:14:35 CDT 2004
Trying to get everything running fine with AG 2.2, I now only have the
problem of the VideoService starting vic with the wrong port (Composite0
instead of S-Video)
Therefore I had a look at the code as I assumed it to be a code problem,
as the other parameters are all set. I stumbled across the following
source code comment:
# Create the port parameter as an option set parameter, now
# that we have multiple possible values for "port"
Does this mean there are several alternatives to specify a port to be
S-Video, for example instead of using a string, just usin a number,
or does it rely to the port type differences between different services?
Furthermore is the correct way to define S-Video as input port to assign
it in the node config file like the following?
[service1]
packagename = VideoService.zip
resource = resource1
serviceconfig = serviceconfig1
[serviceconfig1]
port = S-Video
Michael
Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Website: http://www.hlrs.de/organization/vis/people/braitmaier/
