[AG-TECH] New Fedora Core 2 AGTk CVS snapshot
christoph ganser
ganser at ethworld.ethz.ch
Fri Jul 16 10:51:31 CDT 2004
hi doug
Thanks for the patch.
I applied the patch by hand to VideoProducerService.py.
It now selects correct S-Video input (in the gui of vic). But it is not
grabbing it (the images say blue)! Perhaps it needs some kind of commit?
clicking on the allready seleted value (either device or port) starts
the correct grabbing.
should i try to play around with the value after "after" ? is this a
kind of time out (i know nothing about tcl :( ?
thanks for the help
Christoph
Douglas Kosovic wrote:
> On Fri, 2004-07-16 at 04:34, Fred Dech wrote:
>>and when vic fires up, i still need to change each video capture from
>>Composite1 to S-Video each time i change venues.
> I ended up getting a TV Capture card with more than just a composite
> input and was able to reproduce the problem and then find a possible
> fix.
> There's a problem with the way vic processes the vic setup script (i.e.
> /tmp/VideoService_*.vic) that VideoService.py generates.
> A patch for VideoService.py can found here:
> http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/unstable/patches/VideoService.py.patch
> The VideoService.py file is located in:
> ~/.AccessGrid/local_services/VideoService/
> VideoProducerService.py would need a similar modification if you are
> using the VideoProducerService instead.
> I could incorporate the modified files into VideoService.zip and
> VideoProducerService.zip of a new AccessGrid RPM if the modifications
> work for other people.
> Cheers,
> Doug
Swiss Federal Institute of Technology - Center for Product Development
Tannenstrasse 3 - CLA E 14.1
8092 Zurich - Switzerland
