[AG-TECH] BridgeServer and other problems....
Doiron, Andre
Andre.Doiron at nrc-cnrc.gc.ca
Thu Jul 15 08:40:21 CDT 2004
I was also trying to get the Bridge to work yesterday... I
finally figured out how to make it work just now. The configuration you
posted isn't quite right. Here is what I used, and it worked like a charm.
[BridgeServer]
qbexec = /usr/bin/QuickBridge
name = some_name
location = here
[https://<address>:<port>/Venues/default]
type = Venue
This is for a single Venue, if you want for a server
Put VenueServer as the type, and of course put the correct url.
I had to look into the code to get this working. If you want to see for
yourself it's in the LoadConfig function in the BridgeServer class
Even the examples at the end of the code aren't correct; they don't use the
correct capitalization.
André Doiron
NRC - CNRC
55 Crowley Farm
Moncton, New Brunswick
>Hi everybody.
>I have a few issues and I hope someone can answer some of them:
>1) I'm now successfully running a VenueServer on Redhat 9 machine on an
>intranet, and been able to connect to with an WinXP laptop. Now I am
>trying to run a Bridgeserver (on the same machine) for the venues I
>created.
>This is the config file I use, ~/bridgeconfig.conf:
> [BridgeServer]
>name = BTexact
>location = Adastral Park Ipswich
>venueServer = https://accessgrid.futures.bt.co.uk:8000/VenueServer
<https://accessgrid.futures.bt.co.uk:8000/VenueServer>
>and I execute the command: BridgeServer.py -c ~/bridgeconfig.cnf
>But nothing happens, it doesn't print anything to the screen, and the
>Unicast option is not availables in any of the venues. The logfile doesn't
>give me any hints, this is it's last entry:
>07/14/04 11:54:30 1074127616 CertificateManager
>CertificateManager.py:876 DEBUG Proxy /tmp/x509up_u500 will expire
>07/14/04 18:53:13
> (I even tried to change the last line of the config file to venue =
>https://accessgrid.futures.bt.co.uk:8000/Venues/default
<https://accessgrid.futures.bt.co.uk:8000/Venues/default> but no such
luck.)
>2) Whenever my WinXP connects to a venue and the vic starts up it asks me
>to enter rtpName and rtpEmail and then promises to store it in the Windows
>registry so I won't have to type it again, but it doesn't and I do! And it
>is a bit boring to do it every time! Is this because I am not an
>administrator of the computer? I remember this happening when I installed
>AG on another computer, but if I remember correctly it stopped after I
>rebooted.
>3) I have to start up VenueClient using a Dospromt: VenueClient
>--personalNode. I googled this problem and someone adviced that I removed
>the system variable GLOBUS-HOSTNAME (which I did, although difficult since
>i am not an administrator) and it certainly was wrong, but it didn't fix
>the problem, vic and rat wouldn't start and I couldn't add a
>ServiceManager with hostname:localhost and port:12000. It still uses the
>wrong ip-number.
>4) I cant open a shared browser. I can start the application session (add
>a browser to the venue) but I can't open it on my WinXP (and certainly not
>on my linux, it only works for windows, right?). This I could do when my
>VenueServer was running on a Windows machine.
>This is about it for now. Hope you can help, at least on some of those
>issues.. Thanks.
>Benedikt.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040715/d47482d7/attachment.htm>
