[AG-TECH] Trouble with service certs
Frank Sweetser
fs at WPI.EDU
Fri Jul 16 09:50:58 CDT 2004
On Fri, Jul 16, 2004 at 03:22:11PM +0100, John Hodrien wrote:
> On Fri, 16 Jul 2004, Ivan R. Judson wrote:
> >The first and most important thing is that you can't telnet into the
> >services we've built. They are using the the certificates to negotiate
> >secure encrypted communication. As such, the first thing that needs to
> >happen is a protocol negotiation (that's binary I believe, or at least
> >opaque).
> Yes you can. I'm a developer of Grid based software systems so I know what
> you can and can't do, and this is one I use happily all the time. I'm not
> trying to talk to the system, merely check that it's behaving. A service
> should not immediately close the port when it gets no data, that's a bad
> sign.
The last time I saw this, it turned out that only the public half of my AG
certificate was imported. When it tried to read the private key portion, it
couldn't find the files, and exited in this mysterious way. I don't recall if
I bugzilla'd this or not...
Frank Sweetser fs at wpi.edu
WPI Network Engineer
GPG fingerprint = 6174 1257 129E 0D21 D8D4 E8A3 8E39 29E3 E2E8 8CEC
