[AG-TECH] Using CVS
Ivan R. Judson
judson at mcs.anl.gov
Thu Jul 15 15:20:25 CDT 2004
You should basically be prepared to figure out what broke and submit a
patch. If you're running from cvs we want to know what's broken, but we make
no guarantees you will check out "verified" code.
However, it also looks like you have old code this was fixed and I sent a
notice about it to ag-tech yesterday (early in the morning), I believe.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Miller
> Sent: Thursday, July 15, 2004 3:06 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Using CVS
> When running from CVS using WinXP I get:
> 07/15/04 14:19:34 3712 DataStore datastore.py:273 DEBUG Reading
> persisted da
> ta from: C:\Documents and Settings\mimiller\Application
> Data\AccessGrid\Config\p ersonalDataStore\DataStore.dat
> 07/15/04 14:19:34 3712 VenueClient venueclient.py:215 DEBUG
> __createPersonal
> DataStore: Load personal data from file
> Traceback (most recent call last):
> File "C:\Documents and Settings\mimiller\My
> Documents\UIUC\NCSA\VTS\AG\ag_sour
> ce\ag2.2a\AccessGrid\bin\VenueClient.py", line 107, in ?
> main()
> ce\ag2.2a\AccessGrid\bin\VenueClient.py", line 87, in main
> vcui = VenueClientUI(vc, vcc, app)
> TypeError: __init__() takes exactly 3 arguments (4 given)
> Should I file a bug on something like this? Or should I just
> wait till tomorrow and try updating my CVS.
> I'm wondering if there has been some conflict between the
> AG2.2 installation on my machine and the code running from
> CVS. The Windows instructions only tell me to change my
> PYTHONPATH environment variable, but in the past there were a
> few other things I had to set as well using a script called
> "env-init.bat". Is there something more that might need being done?
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications University of
> Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your
> team with clear objectives, they will invariably do their
> best to achieve everything desired, and usually deliver
> everything you could have hoped for and even more." -Paul Debevec
