[AG-TECH] Using CVS
Ivan R. Judson
judson at mcs.anl.gov
Tue Jul 13 08:28:05 CDT 2004
I just fixed the two instances of this in VenueClient.py and checked them
into cvs.
Please let me know if this fixes the problems.
--Ivan
PS -- Back to getting cvs instructions done.
> -----Original Message-----
> From: Christoph Willing [mailto:willing at itee.uq.edu.au]
> Sent: Monday, July 12, 2004 7:14 PM
> To: Ivan R. Judson
> Cc: 'AG-TECH'
> Subject: RE: [AG-TECH] Using CVS
> On Mon, 2004-07-12 at 23:11, Ivan R. Judson wrote:
> > This is cleanup. We're passing arguments around more clearly now,
> > intead of relying on magic calls into the global ether. I
> think this
> > is fixed in the latest cvs, no?
> Ivan,
> This error only appeared _after_ the cleanup & change to
> wxPython-2.5.1.5. I just did another build (including cvs
> checkout) and this problem remains. This latest build uses
> python2.3, wxPython-2.5.1.5 and AccessGrid-20040713_083537.
> Interestingly, the move away from "magic calls into the global ether"
> seems to be exactly what is being complained about in the last line of
> stdout:
> line 297, in __StartWebService
> self.sm = AGServiceManager(self.server, app)
> NameError: global name 'app' is not defined
> chris
> > > Sent: Sunday, July 11, 2004 5:49 PM
> > > To: Ivan R. Judson
> > > Cc: 'AG Dev'; AG-TECH
> > > Subject: Re: [AG-TECH] Using CVS
> > > On Wed, 2004-07-07 at 22:57, Ivan R. Judson wrote:
> > > > Just a heads up, if you are using the AGTk from CVS,
> you'll have
> > > > to use wxPython/wxWidgets version 2.5 as of yesterday's
> cvs commits.
> > > A new problem with this change (found independently in both
> > > Slackware & Fedora builds): at startup, VenueClient's
> progress bar
> > > almost completes but the whole program crashes before main UI
> > > appears (using wxPythonGTK-2.5.1.5).
> > > Below are outputs from VenueClient.log & stdout.
> > > >From stdout:
> > > ag at v1:~$ VenueClient.py --personalNode bound to port 11000
> > > Traceback (most recent call last):
> > > File "/usr/bin/VenueClient.py", line 107, in ?
> > > main()
> > > File "/usr/bin/VenueClient.py", line 84, in main
> > > progressCB=startupDialog.UpdateOneStep, app=app)
> > > File
> > > "/usr/lib/python2.3/site-packages/AccessGrid/VenueClient.py",
> > > line 119, in __init__
> > > self.__StartWebService(pnode, port)
> > > File
> > > NameError: global name 'app' is not defined ag at v1:~$
> > > >From .AccessGrid/Logs/VenueClient.log:
> > > 07/12/2004 08:24:22 AM 16384 ProxyGen ProxyGen.py:567
> > > DEBUG Using GT24 proxy code
> > > 07/12/2004 08:24:23 AM 16384 Toolkit Toolkit.py:79 DEBUG
> > > Initializing AG Toolkit version 2.2
> > > 07/12/2004 08:24:24 AM 16384 Platform Config.py:931 INFO
> > > registering file type .agpkg with gnome
> > > registering file type .vv2d with gnome
> > > 07/12/2004 08:24:24 AM 16384 Platform Config.py:337 DEBUG
> > > retrieved local IP address 130.102.78.242
> > > 07/12/2004 08:24:24 AM 16384 CertificateManager
> > > CertificateManager.py:261 DEBUG Opened repository
> > > /home/ag/.AccessGrid/Config/certRepo
> > > CertificateManager.py:727 DEBUG Configuring standard environment
> > > CertificateManager.py:793 DEBUG Using default identity /O=Access
> > > Grid/OU=agdev-ca.mcs.anl.gov/OU=vislab.usyd.edu.au/CN=Christop
> > > h Willing
> > > CertificateManager.py:864 DEBUG Initializing environment
> with proxy
> > > cert for /O=Access
> > > h Willing
> > > CertificateManager.py:883 DEBUG Configuring for user proxy issued
> > > from /O=Access
> > > h Willing
> > > CertificateManager.py:886 DEBUG Proxy /tmp/x509up_u1000
> will expire
> > > 11/28/2004 04:37:29 AM
> > > 07/12/2004 08:24:24 AM 16384 VenueClient
> > > VenueClient.py:292 DEBUG __StartWebService: venueclient:
> > > https://130.102.78.242:11000/VenueClient
> Chris Willing Phone: +61 7 3365 8350
> QPSF Access Grid Manager willing at itee.uq.edu.au
> University of Queensland
