[AG-TECH] Using CVS
Christoph Willing
willing at itee.uq.edu.au
Mon Jul 12 19:14:22 CDT 2004
On Mon, 2004-07-12 at 23:11, Ivan R. Judson wrote:
> This is cleanup. We're passing arguments around more clearly now, intead of
> relying on magic calls into the global ether. I think this is fixed in the
> latest cvs, no?
Ivan,
This error only appeared _after_ the cleanup & change to
wxPython-2.5.1.5. I just did another build (including cvs checkout) and
this problem remains. This latest build uses python2.3, wxPython-2.5.1.5
and AccessGrid-20040713_083537.
Interestingly, the move away from "magic calls into the global ether"
seems to be exactly what is being complained about in the last line of
stdout:
line 297, in __StartWebService
self.sm = AGServiceManager(self.server, app)
NameError: global name 'app' is not defined
chris
> > -----Original Message-----
> > From: Christoph Willing [mailto:willing at itee.uq.edu.au]
> > Sent: Sunday, July 11, 2004 5:49 PM
> > To: Ivan R. Judson
> > Cc: 'AG Dev'; AG-TECH
> > Subject: Re: [AG-TECH] Using CVS
> > On Wed, 2004-07-07 at 22:57, Ivan R. Judson wrote:
> > > Just a heads up, if you are using the AGTk from CVS, you'll have to
> > > use wxPython/wxWidgets version 2.5 as of yesterday's cvs commits.
> > A new problem with this change (found independently in both
> > Slackware & Fedora builds): at startup, VenueClient's
> > progress bar almost completes but the whole program crashes
> > before main UI appears (using wxPythonGTK-2.5.1.5).
> > Below are outputs from VenueClient.log & stdout.
> > >From stdout:
> > ag at v1:~$ VenueClient.py --personalNode
> > bound to port 11000
> > Traceback (most recent call last):
> > File "/usr/bin/VenueClient.py", line 107, in ?
> > main()
> > File "/usr/bin/VenueClient.py", line 84, in main
> > progressCB=startupDialog.UpdateOneStep, app=app)
> > File
> > "/usr/lib/python2.3/site-packages/AccessGrid/VenueClient.py",
> > line 119, in __init__
> > self.__StartWebService(pnode, port)
> > File
> > NameError: global name 'app' is not defined ag at v1:~$
> > >From .AccessGrid/Logs/VenueClient.log:
> > 07/12/2004 08:24:22 AM 16384 ProxyGen ProxyGen.py:567
> > DEBUG Using GT24 proxy code
> > 07/12/2004 08:24:23 AM 16384 Toolkit Toolkit.py:79 DEBUG
> > Initializing AG Toolkit version 2.2
> > 07/12/2004 08:24:24 AM 16384 Platform Config.py:931 INFO
> > registering file type .agpkg with gnome
> > registering file type .vv2d with gnome
> > 07/12/2004 08:24:24 AM 16384 Platform Config.py:337 DEBUG
> > retrieved local IP address 130.102.78.242
> > 07/12/2004 08:24:24 AM 16384 CertificateManager
> > CertificateManager.py:261 DEBUG Opened repository
> > /home/ag/.AccessGrid/Config/certRepo
> > CertificateManager.py:727 DEBUG Configuring standard environment
> > CertificateManager.py:793 DEBUG Using default identity
> > /O=Access
> > Grid/OU=agdev-ca.mcs.anl.gov/OU=vislab.usyd.edu.au/CN=Christop
> > h Willing
> > CertificateManager.py:864 DEBUG Initializing environment with
> > proxy cert for /O=Access
> > h Willing
> > CertificateManager.py:883 DEBUG Configuring for user proxy
> > issued from /O=Access
> > h Willing
> > CertificateManager.py:886 DEBUG Proxy /tmp/x509up_u1000 will
> > expire 11/28/2004 04:37:29 AM
> > 07/12/2004 08:24:24 AM 16384 VenueClient
> > VenueClient.py:292 DEBUG __StartWebService: venueclient:
> > https://130.102.78.242:11000/VenueClient
Chris Willing Phone: +61 7 3365 8350
QPSF Access Grid Manager willing at itee.uq.edu.au
University of Queensland
