[AG-TECH] [Fwd: ven]
Benedikt Bjarni Bogason
benedib at hi.is
Mon Jul 12 10:21:23 CDT 2004
Hello.
I'm having problems connecting to VenueServers with my WinXP AG2.2
VenueClient. At first I thought it was a networking problem, but then I
tried to run a VenueServer on the same machine and still couldn't connect
to it. (I seem to connect, but get instantly unconnected). I can't connect
to ANL since I am behind a firewall which doesn't allow connections to it,
else I would have checked if I could get to it.
I include the debug window of the VenueClient (the error is at the bottom)
and it seems be a SOAP error. Does anyone know anything about this?
Benedikt.
07/12/04 16:00:49 1256 Toolkit toolkit.py:79 DEBUG Initializing AG
Toolkit v
ersion 2.2
07/12/04 16:00:49 1256 Toolkit config.py:187 DEBUG Using
GLOBUS_HOSTNAME=128
.40.43.211 as set in the environment
07/12/04 16:00:49 1256 CertificateManager certificatemanager.py:261
DEBUG Op
ened repository C:\Documents and Settings\Administrator\Application
Data\AccessG
rid\Config\certRepo
07/12/04 16:00:50 1256 CertificateManager certificatemanager.py:717
DEBUG Co
nfiguring standard environment
07/12/04 16:00:50 1256 CertificateManager certificatemanager.py:783
DEBUG Us
ing default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=bt.com/CN=Benedik
t Bogason
07/12/04 16:00:50 1256 CertificateManager certificatemanager.py:854
DEBUG In
itializing environment with proxy cert for /O=Access
v/OU=bt.com/CN=Benedikt Bogason
07/12/04 16:00:50 1256 CertificateManager certificatemanager.py:964
DEBUG _V
erifyGlobusProxy: proxy C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\proxy expired
Your identity: /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=bt.com/CN=Benedikt Boga
son
son
user_key loaded
user_proxy cert_chain
verify OK
Creating proxy .......................................................++++++
generated request
gpi signed cert
outfile = C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\proxy
marshal
07/12/04 16:01:13 1256 CertificateManagerWXGUI
certificatemanagerwxgui.py:49
2 DEBUG Proxy successfully created
07/12/04 16:01:13 1256 CertificateManager certificatemanager.py:717
DEBUG Co
07/12/04 16:01:13 1256 CertificateManager certificatemanager.py:783
DEBUG Us
t Bogason
07/12/04 16:01:13 1256 CertificateManager certificatemanager.py:854
DEBUG In
07/12/04 16:01:13 1256 CertificateManager certificatemanager.py:873
DEBUG Co
nfiguring for user proxy issued from /O=Access
07/12/04 16:01:13 1256 CertificateManager certificatemanager.py:876
DEBUG Pr
oxy C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\proxy will expire 07/12/04 17:01:13
DEBUG Co
DEBUG Us
t Bogason
DEBUG In
DEBUG Co
DEBUG Pr
07/12/04 16:01:13 1256 VenueClient venueclient.py:293 DEBUG
__StartWebServic
e: venueclient: https://128.40.43.211:11000/VenueClient
07/12/04 16:01:13 1256 ServiceManager agservicemanager.py:70 INFO
Using ser
vices dir: C:\Documents and Settings\Administrator\Application
Data\AccessGrid\l
ocal_services
07/12/04 16:01:13 1256 ServiceManager agservicemanager.py:453 INFO
__Discov
erResources
07/12/04 16:01:13 1256 VenueClient venueclient.py:302 DEBUG
__StartWebServic
e: service manager: https://128.40.43.211:11000/ServiceManager
07/12/04 16:01:13 1256 NodeService agnodeservice.py:667 INFO
NodeService.__
ReadConfigFile
07/12/04 16:01:13 1256 Toolkit toolkit.py:264 DEBUG Looking for:
C:\Document
Data\AccessGrid\Config\AGNodeService.cf
g
07/12/04 16:01:13 1256 NodeService agnodeservice.py:675 DEBUG DEFAULT
NODE S
ERVICE CONFIG: C:\Documents and Settings\Administrator\Application
Data\AccessGr
id\Config\AGNodeService.cfg
07/12/04 16:01:13 1256 NodeService agnodeservice.py:679 INFO Reading
node s
ervice config file: C:\Documents and Settings\Administrator\Application
Data\Acc
essGrid\Config\AGNodeService.cfg
07/12/04 16:01:13 1256 DataStore datastore.py:1515 DEBUG Creating
thread 0
07/12/04 16:01:13 1256 DataStore datastore.py:1520 DEBUG Starting
thread 0
07/12/04 16:01:13 3248 DataStore datastore.py:1528 DEBUG Worker 0
starting
07/12/04 16:01:13 1256 DataStore datastore.py:1522 DEBUG Waiting
thread 0
07/12/04 16:01:13 1256 DataStore datastore.py:1525 DEBUG Done
creating worke
rs
07/12/04 16:01:13 1256 ServicePackageRepo
agservicepackagerepository.py:63 I
NFO Started AGServicePackageRepository Transfer Server
agservicepackagerepository.py:64 I
NFO url = https://128.40.43.211:53061/packages/
agservicepackagerepository.py:65 I
NFO dir = C:\Program Files\AGTk-2.2\NodeServices
07/12/04 16:01:13 1256 VenueClient venueclient.py:308 DEBUG
__StartWebServic
e: node service: https://128.40.43.211:11000/NodeService
07/12/04 16:01:13 1256 VenueClient venueclient.py:1522 DEBUG
SerNodeUrl: Set
node service url: https://128.40.43.211:11000/NodeService
07/12/04 16:01:13 1256 NodeService agnodeservice.py:360 INFO
NodeService.Lo
adDefaultConfig
07/12/04 16:01:13 1256 NodeService agnodeservice.py:364 INFO Loading
defaul
t node configuration: default
07/12/04 16:01:13 1256 NodeService agnodeservice.py:378 INFO
NodeService.Lo
adConfiguration
07/12/04 16:01:13 1256 NodeService agnodeservice.py:393 INFO Trying
to load
node configuration from: C:\Documents and
Settings\Administrator\Application Da
ta\AccessGrid\Config\nodeConfig\default
07/12/04 16:01:34 1256 NodeService agnodeservice.py:466 INFO
AddServiceMana
ger: Invalid service manager url
(https://128.40.43.211:11000/ServiceManager)
07/12/04 16:01:34 1256 NodeService agnodeservice.py:367 ERROR
Exception load
ing default configuration.
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line
365, in
LoadDefaultConfig
self.LoadConfiguration( self.defaultConfig )
500, in
LoadConfiguration
raise Exception(exceptionText)
Exception: Couldn't reach service manager: 128.40.43.211:11000
07/12/04 16:01:34 1256 VenueClient venueclient.py:317 ERROR Error
loading de
fault configuration
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
315, in _
_StartWebService
self.ns.LoadDefaultConfig()
369, in
LoadDefaultConfig
self.defaultConfig)
Exception: ('Failed to load default configuration <%s>', 'default')
07/12/04 16:01:34 1256 VenueClient venueclient.py:190 DEBUG
__createPersonal
DataStore: Creating personal datastore at C:\Documents and
r\Application Data\AccessGrid\Config\personalDataStore using prefix
personalData
Store and port 0
07/12/04 16:01:34 1256 DataStore datastore.py:1515 DEBUG Creating
thread 0
07/12/04 16:01:34 1256 DataStore datastore.py:1520 DEBUG Starting
thread 0
07/12/04 16:01:34 620 DataStore datastore.py:1528 DEBUG Worker 0
starting
07/12/04 16:01:34 1256 DataStore datastore.py:1522 DEBUG Waiting
thread 0
07/12/04 16:01:34 1256 DataStore datastore.py:1525 DEBUG Done
creating worke
rs
07/12/04 16:01:34 1256 DataStore datastore.py:273 DEBUG Reading
persisted da
ta from: C:\Documents and Settings\Administrator\Application
Data\AccessGrid\Con
fig\personalDataStore\DataStore.dat
07/12/04 16:01:34 1256 VenueClient venueclient.py:215 DEBUG
__createPersonal
DataStore: Load personal data from file
07/12/04 16:02:18 1256 VenueClient venueclient.py:765 DEBUG
EnterVenue; url=
https://accessgrid.futures.bt.co.uk:8000/Venues/default
07/12/04 16:02:18 1256 CertificateManager certificatemanager.py:621
DEBUG Ha
veValidProxy: found proxy ident /O=Access
/CN=Benedikt Bogason/CN=proxy
07/12/04 16:02:38 1256 VenueClient venueclient.py:790 INFO
EnterVenue: Erro
r getting node capabilities
07/12/04 16:02:39 1256 VenueClient venueclient.py:686 DEBUG
EnterVenue: Invo
ke venue enter
07/12/04 16:02:39 1256 VenueClient venueclient.py:653 ERROR SOAP fault
occur
red
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in __call
config = self.config)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
r.endheaders()
File "C:\Python23\lib\httplib.py", line 712, in endheaders
self._send_output()
File "C:\Python23\lib\httplib.py", line 597, in _send_output
self.send(msg)
File "C:\Python23\lib\httplib.py", line 564, in send
self.connect()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in connect
raise ex
GSITCPSocketException: the name accessgrid.futures.bt.co.uk could not be
resolve
d
07/12/04 16:02:39 1256 VenueClient venueclient.py:824 ERROR
EnterVenue: glob
us tcp exception: ('the name accessgrid.futures.bt.co.uk could not be
resolved',
07/12/04 16:02:39 1256 VenueClient venueclient.py:831 ERROR
EnterVenue: fail
ed
794, in E
nterVenue
self.__EnterVenue(URL)
687, in _
_EnterVenue
(venueState, self.privateId, self.streamDescList ) =
self.__venueProxy.Enter
( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3096, in
Enter
(r1, r2, r3) = self.proxy.Enter(profile)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
__call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
__r_call
self.__hd, self.__ma)
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
resolve
d
07/12/04 16:02:39 1256 VenueClientUI venueclientui.py:2053 DEBUG
bin.VenueCl
ient::EnterVenue: Enter venue with url:
/Venues/default
07/12/04 16:02:39 1256 VenueClientUI venueclientui.py:2066 DEBUG
warningStri
ng:
