[AG-TECH] Using CVS
Ivan R. Judson
judson at mcs.anl.gov
Mon Jul 12 08:11:22 CDT 2004
This is cleanup. We're passing arguments around more clearly now, intead of
relying on magic calls into the global ether. I think this is fixed in the
latest cvs, no?
--Ivan
> -----Original Message-----
> From: Christoph Willing [mailto:willing at itee.uq.edu.au]
> Sent: Sunday, July 11, 2004 5:49 PM
> To: Ivan R. Judson
> Cc: 'AG Dev'; AG-TECH
> Subject: Re: [AG-TECH] Using CVS
> On Wed, 2004-07-07 at 22:57, Ivan R. Judson wrote:
> > Just a heads up, if you are using the AGTk from CVS, you'll have to
> > use wxPython/wxWidgets version 2.5 as of yesterday's cvs commits.
> A new problem with this change (found independently in both
> Slackware & Fedora builds): at startup, VenueClient's
> progress bar almost completes but the whole program crashes
> before main UI appears (using wxPythonGTK-2.5.1.5).
> Below are outputs from VenueClient.log & stdout.
> >From stdout:
> ag at v1:~$ VenueClient.py --personalNode
> bound to port 11000
> Traceback (most recent call last):
> File "/usr/bin/VenueClient.py", line 107, in ?
> main()
> File "/usr/bin/VenueClient.py", line 84, in main
> progressCB=startupDialog.UpdateOneStep, app=app)
> File
> "/usr/lib/python2.3/site-packages/AccessGrid/VenueClient.py",
> line 119, in __init__
> self.__StartWebService(pnode, port)
> File
> line 297, in __StartWebService
> self.sm = AGServiceManager(self.server, app)
> NameError: global name 'app' is not defined ag at v1:~$
> >From .AccessGrid/Logs/VenueClient.log:
> 07/12/2004 08:24:22 AM 16384 ProxyGen ProxyGen.py:567
> DEBUG Using GT24 proxy code
> 07/12/2004 08:24:23 AM 16384 Toolkit Toolkit.py:79 DEBUG
> Initializing AG Toolkit version 2.2
> 07/12/2004 08:24:24 AM 16384 Platform Config.py:931 INFO
> registering file type .agpkg with gnome
> registering file type .vv2d with gnome
> 07/12/2004 08:24:24 AM 16384 Platform Config.py:337 DEBUG
> retrieved local IP address 130.102.78.242
> 07/12/2004 08:24:24 AM 16384 CertificateManager
> CertificateManager.py:261 DEBUG Opened repository
> /home/ag/.AccessGrid/Config/certRepo
> CertificateManager.py:727 DEBUG Configuring standard environment
> CertificateManager.py:793 DEBUG Using default identity
> /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=vislab.usyd.edu.au/CN=Christop
> h Willing
> CertificateManager.py:864 DEBUG Initializing environment with
> proxy cert for /O=Access
> h Willing
> CertificateManager.py:883 DEBUG Configuring for user proxy
> issued from /O=Access
> h Willing
> CertificateManager.py:886 DEBUG Proxy /tmp/x509up_u1000 will
> expire 11/28/2004 04:37:29 AM
> 07/12/2004 08:24:24 AM 16384 VenueClient
> VenueClient.py:292 DEBUG __StartWebService: venueclient:
> https://130.102.78.242:11000/VenueClient
> Chris Willing Phone: +61 7 3365 8350
> QPSF Access Grid Manager willing at itee.uq.edu.au
> University of Queensland
