[AG-TECH] Using CVS
Christoph Willing
willing at itee.uq.edu.au
Sun Jul 11 17:48:52 CDT 2004
On Wed, 2004-07-07 at 22:57, Ivan R. Judson wrote:
> Just a heads up, if you are using the AGTk from CVS, you'll have to use
> wxPython/wxWidgets version 2.5 as of yesterday's cvs commits.
A new problem with this change (found independently in both Slackware &
Fedora builds): at startup, VenueClient's progress bar almost completes
but the whole program crashes before main UI appears (using
wxPythonGTK-2.5.1.5).
Below are outputs from VenueClient.log & stdout.
>From stdout:
ag at v1:~$ VenueClient.py --personalNode
bound to port 11000
Traceback (most recent call last):
File "/usr/bin/VenueClient.py", line 107, in ?
main()
File "/usr/bin/VenueClient.py", line 84, in main
progressCB=startupDialog.UpdateOneStep, app=app)
File "/usr/lib/python2.3/site-packages/AccessGrid/VenueClient.py", line 119, in __init__
self.__StartWebService(pnode, port)
File "/usr/lib/python2.3/site-packages/AccessGrid/VenueClient.py", line 297, in __StartWebService
self.sm = AGServiceManager(self.server, app)
NameError: global name 'app' is not defined
ag at v1:~$
>From .AccessGrid/Logs/VenueClient.log:
07/12/2004 08:24:22 AM 16384 ProxyGen ProxyGen.py:567 DEBUG Using GT24 proxy code
07/12/2004 08:24:23 AM 16384 Toolkit Toolkit.py:79 DEBUG Initializing AG Toolkit version 2.2
07/12/2004 08:24:24 AM 16384 Platform Config.py:931 INFO registering file type .agpkg with gnome
07/12/2004 08:24:24 AM 16384 Platform Config.py:931 INFO registering file type .vv2d with gnome
07/12/2004 08:24:24 AM 16384 Platform Config.py:337 DEBUG retrieved local IP address 130.102.78.242
07/12/2004 08:24:24 AM 16384 CertificateManager CertificateManager.py:261 DEBUG Opened repository /home/ag/.AccessGrid/Config/certRepo
07/12/2004 08:24:24 AM 16384 CertificateManager CertificateManager.py:727 DEBUG Configuring standard environment
07/12/2004 08:24:24 AM 16384 CertificateManager CertificateManager.py:793 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=vislab.usyd.edu.au/CN=Christoph Willing
07/12/2004 08:24:24 AM 16384 CertificateManager CertificateManager.py:864 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=vislab.usyd.edu.au/CN=Christoph Willing
07/12/2004 08:24:24 AM 16384 CertificateManager CertificateManager.py:883 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=vislab.usyd.edu.au/CN=Christoph Willing
07/12/2004 08:24:24 AM 16384 CertificateManager CertificateManager.py:886 DEBUG Proxy /tmp/x509up_u1000 will expire 11/28/2004 04:37:29 AM
07/12/2004 08:24:24 AM 16384 VenueClient VenueClient.py:292 DEBUG __StartWebService: venueclient: https://130.102.78.242:11000/VenueClient
Chris Willing Phone: +61 7 3365 8350
QPSF Access Grid Manager willing at itee.uq.edu.au
University of Queensland
