[AG-TECH] VideoProducerService is also receiving???
Michael Miller
mimiller at ncsa.uiuc.edu
Fri Jul 9 10:23:58 CDT 2004
Adam,
I think you should submit your doc to the AGDP:
http://www.accessgrid.org/agdp/
Michael Miller
NCSA
At 10:11 AM 7/9/2004, ULM AccessGrid wrote:
>UPDATE:
>I found a quick way to make the VICs on my video machine transmit(sort of)
>only. I just added a firewall line that blocked all incoming sources that
>were not on my subnet. I now have three VICs with only one video per VIC on
>my video box. Thanks Michael for letting me know it was not just me. You
>helped me think of this solution. FINALLY AG2.2 is running well on my
>multi-os node.
>I am in the process of making a comprehensive HOW-TO to install AG2.2 on
>Fedora2. It should be finished within the hour. It will come with links to
>all files needed for the install.
>Here's the link:
>http://198.232.231.51/install.txt
>Let me know what you think.
>Thanks
>Adam Taylor
>Computing Center
>University of Louisiana at Monroe
>-----Original Message-----
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
>Of Michael Miller
>Sent: Friday, July 09, 2004 8:14 AM
>To: ag-tech at mcs.anl.gov
>Subject: Re: [AG-TECH] VideoProducerService is also receiving???
>Adam,
>I've seen this question a couple times. Yes, this is normal behavior in my
>experience. You should notice though that all the streams in the
>VideoProducer VICs muted. I believe this eliminates the bandwith usage
>that those streams would need, but there still maybe a small amount in
>order for VIC to know that the stream is still there. I'll let the vic
>experts chime in here...
>It would make more sense if a single instance of VIC could be configured to
>handle multiple inputs/transmits but I'll bet there would be a whole lot of
>changes to the code necessary to handle that.
>hope this helps
>Michael Miller
>NCSA
>At 06:31 PM 7/8/2004, Adam Taylor wrote:
> >I have a weird problem. When I add my three VideoProducerServices they
> >add without a problem. When I join the venue the weirdness begins. My
> >three VIC s on my Fedora2(Video Capture) box comes up with my three
> >cameras (one camera for each instance of VIC). The problem is that all
> >three VICs receive ALL the other video streams in the venue also. I have
> >three duplicate pairs of the incoming video streams. However there is
> >only one instance of each of my cameras (One camera on each VIC like it is
> >suppose to). Can anyone tell me why my three VideoProducerServices VICs
> >are also receiving Video too???
> >When I join a venue without anybody I get three VICs with one camera on
> >each like there are suppose to do. If someone joins the venue, those
> >three instances of VIC each receive all of the other persons video
> >streams too.
> >I m sorry if I double stated it but I just wanted to make sure I was as
> >clear as possible.
> >Thanks
> >Adam Taylor
> >Computing Center
> >University of Louisiana at Monroe.
>Thanx,
>Michael Miller
>System Engineer
>Visualization Technology Support
>Computing and Data Management
>National Center for Supercomputing Applications
>University of Illinois - UC
>217-649-0747
>"If you're clear in your vision and trust the people in your team with
>clear objectives, they will invariably do their best to achieve everything
>desired, and usually deliver everything you could have hoped for and even
>more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
