[AG-TECH] VideoProducerService is also receiving???
ULM AccessGrid
accessgrid at ulm.edu
Fri Jul 9 10:11:23 CDT 2004
UPDATE:
I found a quick way to make the VICs on my video machine transmit(sort of)
only. I just added a firewall line that blocked all incoming sources that
were not on my subnet. I now have three VICs with only one video per VIC on
my video box. Thanks Michael for letting me know it was not just me. You
helped me think of this solution. FINALLY AG2.2 is running well on my
multi-os node.
I am in the process of making a comprehensive HOW-TO to install AG2.2 on
Fedora2. It should be finished within the hour. It will come with links to
all files needed for the install.
Here's the link:
http://198.232.231.51/install.txt
Let me know what you think.
Thanks
Adam Taylor
Computing Center
University of Louisiana at Monroe
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Michael Miller
Sent: Friday, July 09, 2004 8:14 AM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] VideoProducerService is also receiving???
Adam,
I've seen this question a couple times. Yes, this is normal behavior in my
experience. You should notice though that all the streams in the
VideoProducer VICs muted. I believe this eliminates the bandwith usage
that those streams would need, but there still maybe a small amount in
order for VIC to know that the stream is still there. I'll let the vic
experts chime in here...
It would make more sense if a single instance of VIC could be configured to
handle multiple inputs/transmits but I'll bet there would be a whole lot of
changes to the code necessary to handle that.
hope this helps
Michael Miller
NCSA
At 06:31 PM 7/8/2004, Adam Taylor wrote:
>I have a weird problem. When I add my three VideoProducerServices they
>add without a problem. When I join the venue the weirdness begins. My
>three VIC s on my Fedora2(Video Capture) box comes up with my three
>cameras (one camera for each instance of VIC). The problem is that all
>three VICs receive ALL the other video streams in the venue also. I have
>three duplicate pairs of the incoming video streams. However there is
>only one instance of each of my cameras (One camera on each VIC like it is
>suppose to). Can anyone tell me why my three VideoProducerServices VICs
>are also receiving Video too???
>When I join a venue without anybody I get three VICs with one camera on
>each like there are suppose to do. If someone joins the venue, those
>three instances of VIC each receive all of the other persons video
>streams too.
>I m sorry if I double stated it but I just wanted to make sure I was as
>clear as possible.
>Thanks
>Adam Taylor
>Computing Center
>University of Louisiana at Monroe.
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
