[AG-TECH] rpm vs. rpmbuild with Core 2
Frank Sweetser
fs at WPI.EDU
Tue Jul 6 11:28:36 CDT 2004
On Tue, Jul 06, 2004 at 11:08:05AM -0500, Joshua M. Brown wrote:
> ...er, how does that effect the rpm build scripts if i'm trying to build
> AG2.2 on Fedora Core 2? The reason i ask is to avoid beating my head
> against any walls that i don't have to :)
The only things that might have changed a little are the command line options
that you use when invoking rpm builds - the contents of the spec file shouldn't
need to be changed. Basically, it just means that instead of running
rpm -ba specfile.spec
you run
rpmbuild -ba specfile.spec
Frank Sweetser fs at wpi.edu
WPI Network Engineer
GPG fingerprint = 6174 1257 129E 0D21 D8D4 E8A3 8E39 29E3 E2E8 8CEC
