[AG-TECH] problems starting AGNodeService ...
Randy Groves
randy.groves at boeing.com
Tue Jul 6 11:44:32 CDT 2004
For those of us using XP, the following works in a command window:
taskkill /im pythonw.exe /f /t
Nice for cleaning up if there are more than one pythonw process running.
-randy
At 06:48 AM 7/6/2004, Sabihuddin, Siraj wrote:
>I've noticed the same problem occasionally here at NRC (both on PIG nodes
>and our multi-machine node in windows). Usually this is caused by stray
>python processes still running after the Venue Client has shutdown
>improperly. (I'm not certain whether the service manager contributes to the
>problem)
>Going into the task manager and killing off these processes before restart
>usually fixes the problem. Occasionally it is necessary to reboot the
>machine to get the VenueClient running again.
>Siraj
>Student Programmer
>Information Security Group, Institute for Information Technology
>National Research Council (NRC), Ottawa, Canada
>Email: Siraj.Sabihuddin at nrc-cnrc.gc.ca,
>WWW - NRC: http://iit-iti.nrc-cnrc.gc.ca
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> > Behalf Of Darran Edmundson
> > Sent: Monday, July 05, 2004 11:09 PM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] problems starting AGNodeService ...
> > I'm having problems with AGTk2.2 in that the VenueClient
> > is hanging on startup. You know, when the progress bar
> > zips across to about 75% complete and then pauses
> > indefinitely. (This under WinXP.)
> > Trying things manually, AGServiceManager seems to start
> > up fine but then I get the following with AGNodeService:
> > C:\Program Files\AGTk-2.2\bin>python AGNodeService.py
> > <Fault SOAP-ENV:Client: Method Not Found: ServiceManager:IsValid :
> > exceptions.Ke
> > yError 'ServiceManager' <traceback object at 0x01281CD8>>
> > Error loading default node configuration
> > Has anyone else observed this? Same problem whether
> > or not ServiceManagers are running on the other two
> > machines in the node.
> > Cheers,
> > Darran.
