[AG-TECH] That freezin' rat
Colin Perkins
csp at csperkins.org
Thu Jan 22 15:23:47 CST 2004
--> "Don Morton" <Don.Morton at umontana.edu> writes:
> Before I go off into all sorts of wrong directions,
> I thought I'd ask for advice here.....
> I have a RedHat 7.3 setup, connected to multicast,
> and vic works fine, both transmitting and receiving.
> On rat, however, it just hangs when I try to launch
> it, as in
> rat 233.1.171.179/59700 (or any address I give it, even
> if it's a unicast to a QuickBridge)
> This happens with a rat from AG1, and the rat from the most
> recent AG2.
> I know someone else ran into this when she was on a bad network,
> but that's not the case here.
> Is this something that others see frequently and might have quick
> workarounds for?
Rat uses host local multicast as an inter-process communication mechanism.
If rat doesn't start it's most likely because this isn't getting through:
either a firewall issue (udp port 47000) or a multicast routing issues.
Colin Perkins
http://csperkins.org/
