[AG-TECH] vic issue.
Jonathan Silverstein
jcs at uchicago.edu
Wed Feb 25 09:26:21 CST 2004
I believe also on the receiving end there is a function for window size
(selecting the streaming video window and pressing s,m, or l) that,
when shift is held at the same time changes the size of "s,m, or l" on
the display also eliminating the gray outline - useful when you are
receiving such a stream rather than sending. Bottom line, its a
feature not a bug.
Cheers,
Jonathan
On Feb 25, 2004, at 9:13 AM, Michael Miller wrote:
> Jennifer,
> when you have vic up and running, click the menu button, in the dialog
> that comes up there is an "options" button. Select "Configure on
> Transmit" from there. Then click the "release" button then click
> "Transmit" button. When you click "Transmit" a dialog appears where
> you can choose the size of the video. Pick 352X288. When you click
> OK, another dialog will appear allowing you to change settings for the
> camera.
> Depending on the driver you can do the same with other cameras. My
> iBot firewire camera doesn't offer the 352X288 size.
> Hope this helps
> Michael Miller
> NCSA
> At 08:40 AM 2/25/2004, you wrote:
>> Hello,
>> I m having a problem with the size of my displayed video stream. My
>> video does not fill up its window on the vic, but rather it appears
>> as a small video window surrounded by a large grey border. If you
>> want to see what I mean, let me know and I ll meet you in the test
>> room.
>> I am running a PIG (version 2.1.2) on Windows XP, using a logitech
>> quick cam and my vic version is v2.8ucl-1.1.3-AG. In the vic menu,
>> the encoder is set to h261 and the size is set to normal.
>> I m not sure when this problem started& if it started when I loaded
>> v.2.1.2, or if it started before. Also, I don t have this issue when
>> I use the vic in VRVS which is vic version v5.3-by VRVS.
>> Any suggestions?
>> Thanks!
>> Jennifer Hare
>> Systems Programmer
>> Strategic Initiatives
>> Information Technology & Computing Services
>> East Carolina University
>> <mailto:harej at mail.ecu.edu>harej at mail.ecu.edu
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have
> hoped for and even more." -Paul Debevec
