[AG-TECH] hauppauge video problems
Don Lewis
djlewis at ualr.edu
Wed Feb 11 12:32:52 CST 2004
Lately I've been getting complaints on the quality of our
inhouse video going out to AG land. We are still using the original
Haupauge WinTV model 404. Is there a better solution
for an existing VIC to improve color and s/n?
Is it the Spectra8 card?
Don Lewis
>===== Original Message From Bob Riddle <bdr at internet2.edu> =====
>I actually use a Spectra8 card on our "loaner" AG - it has four video
>ports on it and works the way Michael describes. I've been trying to do
>the same thing with a 4-port Winnov card as well ... (you know, there
>are only so many PCI port in a one-box node!)
>Michael Miller wrote:
>> Just to add to what Ti said:
>> My experience has been that, depending on the driver, you can select
>> the WDM device in the configuration of multiple VideoProducers. When
>> vic starts up, one of the WDM cameras is automatically selected for
>> the first VideoProducer. Then you are given a series of dialogs to
>> choose a camera for each remaining VideoProducer. Again, whether you
>> get to choose another camera will depend on how the driver enumerates
>> the cameras. The QuickCam Pro 4000 does show you multiple cameras,
>> but it gives them all the same name. So, it can be confusing when
>> trying to choose a camera for the subsequent VideoProducers. If you
>> have two different cameras, the WDM drivers will assign names as
>> appropriate and it's much easier to decide which camera to choose. I
>> have an iBot firewire camera and a QuickCam Pro 4000 so I can see
>> which camera has become the default after the last session. If you
>> have two of the same camera and the driver doesn't assign each a
>> unique name, that's when you run into trouble.
>> HTH
>> Michael Miller
>> NCSA
>> At 05:36 PM 2/10/2004, Ti Leggett wrote:
>>> Actually the problem is this. Vic can only handle Video for Windows (VfW
>>> devices) which is an old driver style. vic can map the newer WDM drivers
>>> to a VfW device, but it can only do that for one device. Basically, if
>>> you have drivers that are VfW then all of them will be seen and usable
>>> in vic. If the drivers are WDM only, then vic will pick a device and map
>>> and that's it. Hauppage has stopped providing VfW drivers for their
>>> cards. Osprey, however, still provides VfW drivers for their cards.
>>> This driver issue is also why you can only have one web cam hooked up
>>> since, I'd say, all web cams provide only WDM drivers.
>>> Make more sense?
>>> On Wed, 2004-02-11 at 08:35, Bob Riddle wrote:
>>> > for what it's worth - I've been down this road and gave up - while
>>> this
>>> > is no problem on Linux, the driver for WinXP assumes that only one
>>> WinTV
>>> > card will be on the system. It cost less for a couple of Osprey100
>>> > cards than it did for the time I spent on trying to make this work.
>>> > sigh.
>>> > Harold Micheal Goldman wrote:
>>> > > Does anyone know of any way to get two hauppauge WinTv video
>>> capture cards to
>>> > >work at the same time in Windows XP. I am creating an Access Grid
>>> Node here at
>>> > >the University of Southern Mississippi for Collaboration for
>>> Genomic Research.
>>> > >I will also be setting up similar agn's at four othe universities
>>> here in the
>>> > >state. I had bought the two cards on the advice of a friend that
>>> admins a agn
>>> > >for the computer science dept here at usm, but we cannot get both
>>> cards to work
>>> > >under xp.
>>> > > Thank You
>>> > > Mike Goldman
>>> > > Bioinformatics Coordinator
>>> > > MFGN USM
>> Thanx,
>> Michael Miller
>> System Engineer
>> Visualization Technology Support
>> Computing and Data Management
>> National Center for Supercomputing Applications
>> University of Illinois - UC
>> 217-649-0747
>> "If you're clear in your vision and trust the people in your team with
>> clear objectives, they will invariably do their best to achieve
>> everything desired, and usually deliver everything you could have
>> hoped for and even more." -Paul Debevec
>Bob Riddle (bdr at internet2.edu) Technologist,Internet2
>3025 Boardwalk, Suite 100 Ann Arbor, Michigan 48108
>Business Phone: 734.913.4257 Fax Number: 734.913.4255
>"Opportunity is missed by most people because it is dressed in overalls and
looks like work" Thomas Edison
Don Lewis
Senior Computer Specialist
Graduate Institute of Technology
ETAS 335A, 2801 South University Avenue
University of Arkansas at Little Rock 72204
(501) 569-8016 fax: (501) 569-8039
djlewis at ualr.edu
