[AG-TECH] Audio expertise needed for document!
Jennifer Teig von Hoffman
jtvh at bu.edu
Mon Feb 9 08:27:50 CST 2004
Kazuyuki,
Those are very good points, thank you.
I'm happy to say that Mike Miller of NCSA has volunteered to update the
document, and Eric Brown of Virginia Tech will be helping him out as
well. They both have a great deal of expertise with audio systems, and
perhaps can consider your suggestions.
Cheers,
Jennifer
shudo at ni.aist.go.jp wrote:
> From: Jennifer Teig von Hoffman <jtvh at bu.edu>
>>Hi all,
>>The AGDP is badly in need of somebody to do the next revision of our
>>document on configuring Gentner hardware for use with the AG. Geez, it
>>even still calls it a Gentner!
> I completely agree with you that the document is to be updated.
> I have another point. ClearOne's products are the only choices we
> have.
> I could have a talk with an agency of Polycom about difference between
> ClearOne's products and Polycom's products. Of course, he asserted
> the Polycom's are superior to the ClearOne's in many points such as
> adaptivity to audio latency and easy configuration. I could not
> confirm his assertion by myself but it sounds fairly reliable.
> The only reason I got Gentner AP400 is the recipes for AG node say it
> works well. The documents have much influence on the purchase of echo
> canceller by AG node builders.
> Kazuyuki Shudo shudo at computer.org http://www.shudo.net/
