[AG-TECH] Python error on AG installation
Robert Olson
olson at mcs.anl.gov
Fri Feb 6 07:58:42 CST 2004
Ah, good find. I'll do some testing with the IPV6 stack installed and see
if I can reproduce this.
(Also entered into bugzilla as bug 852).
--bob
At 07:16 AM 2/6/2004, Douglas Baggett wrote:
>The problem seemed to have to do with the fact that I had the IPV6 stack
>installed under WinXP. As soon as I uninstalled it the client didn't have
>a problem enumerating my adapter and reverse resolving my workstation's
>address. I wonder if this is a bug in the python module that was used in
>the script? It looks like the problem is in winnet.enumerate_interfaces()
>within the globus python script.
>network query raised exception
>Traceback (most recent call last):
> File "\PROGRA~1\ACCESS~2\bin\globus_init.pyw", line 802, in
> ThreadQueryFunc
> self.interfaces = winnet.enumerate_interfaces()
>-Doug B
>CISE/NSF
>Frank Sweetser wrote:
>>On Thu, Feb 05, 2004 at 03:35:08PM -0500, Douglas Baggett wrote:
>>>> File "C:\Python22\Lib\site-packages\DNS\Base.py", line 137, in conn
>>>> self.s.connect((self.ns,self.port))
>>>> File "<string>", line 1, in connect
>>>>gaierror: (7, 'getaddrinfo failed')
>>>It seems like it's having problems doing a reverse lookup on my
>>>hostname, but I'm able to reverse resolve my address using nslookup
>>>without any problems. Is this a bug or is it something I should be
>>>concerned with?
>>Are you sure that nslookup is using DNS? I've caught windows nslookup
>>silently falling back to WINS resolution when DNS doesn't have an
>>answer.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040206/ca0ddd36/attachment.htm>
