[AG-TECH] AG 2.1.2 venue server setup
Christoph Willing
chris at vislab.usyd.edu.au
Thu Feb 5 16:38:46 CST 2004
On Fri, 2004-02-06 at 08:52, Darin Oman wrote:
> Is there any documentation anywhere on installing and configuring an
> AG 2.1.2 venue server on Linux?
Darin,
There's not much to do if have already installed the AG2.1.2 bundle and
have a certificate for the user who will run the server. In that case,
start the server with by running (from the command line):
VenueServer.py
For general use, it may be easier to start the server at boot time using
a script in /etc/rc.d (example below).
Once the server is running, it is configured with the the
VenueManagement tool - either VenueManagement.py from the command line
or from the Applications->Other->Venue Manager menu item (this may
differ on your system, depending on which window manager you're using).
You can pretty much follow your nose from there; the buttons are fairly
obvious for adding/modifying rooms, which will be your most common
activity.
chris
Example /etc/rc.d/rc.agvs script to start Venue Server at boot time. It
is assumed the server is being run as the user "ag" and that this user
has a service certificate (rather than identity certificate).
#!/bin/sh
# agvs This shell script takes care of starting and stopping
# the Access Grid Venue Server
# description: The Access Grid Service Manager
[ -x /usr/bin/VenueServer.py ] || exit
RETVAL=0
prog="VenueServer"
datadir="/var/run/agvs"
start() {
# Start daemons.
touch /var/log/agvs.log
chown ag.users /var/log/agvs.log
chmod 0640 /var/log/agvs.log
if [ ! -d $datadir ]; then
mkdir -p $datadir
chown -R ag.users $datadir
chmod 0640 $datadir
fi
echo -n $"Starting $prog: "
su ag -c '/usr/lib/globus/bin/grid-proxy-init -hours 0'
(cd ~ag && su ag -c /usr/bin/VenueServer.py &)
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && touch /var/lock/subsys/agvs
return $RETVAL
stop() {
# Stop daemons.
echo -n $"Shutting down $prog: "
killall VenueServer.py
sleep 3
killall -HUP VenueServer.py
RETVAL=$?
echo
if [ -d $datadir ]; then
rm -rf $datadir
fi
[ $RETVAL -eq 0 ] && rm -f /var/lock/subsys/agvs
return $RETVAL
# See how we were called.
case "$1" in
start)
start
stop)
stop
status)
status agvs
RETVAL=$?
restart|reload)
stop
start
RETVAL=$?
condrestart)
if [ -f /var/lock/subsys/agvs ]; then
stop
start
RETVAL=$?
fi
echo $"Usage: $0 {start|stop|restart|condrestart|status}"
exit 1
esac
exit $RETVAL
# End of rc.agvs script
Chris Willing Telephone (61-2) 9351 3914
Sydney Vislab, F09 Fax (61-2) 9351 5955
University of Sydney
NSW 2006 Australia http://www.vislab.usyd.edu.au
