[AG-TECH] Success Using Other CA's?
Todd Zimmerman
toddz at sfu.ca
Mon Feb 2 11:43:56 CST 2004
Thanks for the note Lewis. Our symptoms were exactly the same as yours.
Since I haven't heard from anyone else on this - I'm assuming that no
one has successfully accomplished this yet?
Our organization would _really_ like to get this going - since all of
our authentication already takes place using Grid Canada certs, and it
seems redundant to require getting ANL certs - especially when
integration seems _so_ close to working properly.
Can any of the developers give a bit of a status update on this
feature/bug - and perhaps give a bit of a hint of where to start looking
if one (foolishly ;-) ) wanted to try to fix it themselves??
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Lewis Grantham wrote:
> hi Todd
>> Hi all,
>> Has anyone had any success importing other CA's and using non-ANL
>> certs for authentication??
>> I'm having a few issues with the service/node managers working
>> properly while using GridCanada issued certificates.
>> Any advice or hints would be appreciated.
> none of those, but same experience as yours.
> Other CAs and certs import ok (CA first, then cert obviously), and PIG
> with personal services appear to run under these with little clear
> difference.
> however, the node manager in particular cannot be engaged, so you wont
> really have a working system - the VenueClient link to manage node
> will simple report no node accessible found at address or something
> like that, and ask for an alternate ip address/port.
> the quickest way to get going is to run an anl supplied cert for now.
> Im not aware of any work arounds or fixes.
> bye
> lewis
