[AG-TECH] grid-proxy-info & init
Robert Olson
olson at mcs.anl.gov
Mon Feb 2 08:53:49 CST 2004
Why do you need to run grid-proxy-init? Is it for the AG software, or for
other apps using the certificate?
Any of the AG tools requiring a proxy should be invoking the AGTk
mechanisms for creating them, and not relying on grid-proxy-init.
--bob
At 04:48 PM 2/1/2004, Christoph Willing wrote:
>This isn't really a bug, more of a feature request -
>New identity certificates aquired recently are issued by AG Developers
>and, in Linux systems, are stored in the user's .AccessGrid directory
>tree. The previously issued Globus identity certificates were stored in
>the user's .globus directory.
>Although grid-proxy-info is able find these newer certificates and
>report on them, grid-proxy-init will not work. It looks in the .globus
>directory, which doesn't exist for the newer certificates. The actual
>output is:
>~$ grid-proxy-init
>user certificate not found
> Cert File=/var/lib/ag/.globus/usercert.pem
>Function: proxy_init_cred
>The -cert and -key options to grid-proxy-init will work to make
>grid-proxy-init look in different locations, but these locations are
>horrendously error-prone e.g for one particular machine, I need to type:
>grid-proxy-init -key
>.AccessGrid/certRepo/privatekeys/3915260c10f91fe25bd690a4f80c0037.pem
>-cert
>.AccessGrid/certRepo/certificates/f5d473eee6f6e6c97266997422a5ca54/f05e3a2e909373343c5378059f861381/cert.pem
>Could grid-proxy-init be modified to be as smart as grid-proxy-info in
>searching for certificates i.e. that it automatically searches the
>.AccessGrid tree?
>chris
>Chris Willing Telephone (61-2) 9351 3914
>Sydney Vislab, F09 Fax (61-2) 9351 5955
>University of Sydney
>NSW 2006 Australia http://www.vislab.usyd.edu.au
