[AG-TECH] AGNodeService.py not in Fredora RPM
    Thomas D. Uram
    turam at mcs.anl.gov
    Thu Dec 16 16:28:47 CST 2004
Steve:
As of 2.3, the node service is run as part of the service manager, with the '-n' option:
AGServiceManager.py -n
Also, if this is a single machine node, you can start the local node service and service
manager when the venue client starts, like so:
VenueClient.py --personalNode
Hope this helps,
Tom
Steve Gallo wrote:
> Hi All,
> I've followed the instructions at
> http://www.itee.uq.edu.au/~grangenet/ag_fedora/
> for installing AG2.3 on RHEL3 and am having the following problem.
> /etc/init.d/agns references /usr/bin/AGNodeService.py, but that
> file does not exist, so I cannot start node services.  I've checked
> the slackware distribution and the agns init script exists there
> also but no AGNodeService.py.
> When I start up VenueClient.py and try to "Manage My Node" using
> the default URL of https://localhost:11000/NodeService it fails
> with the following error:
> <Fault SOAP-ENV:Client: Method Not Found: NodeService:IsValid : exceptions.KeyError NodeService <traceback object at 0x9fd1fd4>>
> I've checked the RPM and it doesn't seem to have an AGNodeServices.py file:
> #> rpm -qlp AccessGrid-2.3-6.i386.rpm | fgrep -i nodeservice
> /etc/AccessGrid/Config/AGNodeService.cfg
> /etc/AccessGrid/NodeServices
> /etc/AccessGrid/NodeServices/AudioService.zip
> /etc/AccessGrid/NodeServices/VideoConsumerService.zip
> /etc/AccessGrid/NodeServices/VideoProducerService.zip
> /etc/AccessGrid/NodeServices/VideoService.zip
> /usr/lib/python2.2/site-packages/AccessGrid/AGNodeService.py
> /usr/lib/python2.2/site-packages/AccessGrid/AGNodeService.pyc
> /usr/lib/python2.2/site-packages/AccessGrid/AGNodeService.pyo
> /usr/lib/python2.2/site-packages/AccessGrid/tests/test_NodeService.py
> /usr/lib/python2.2/site-packages/AccessGrid/tests/test_NodeService.pyc
> /usr/lib/python2.2/site-packages/AccessGrid/tests/test_NodeService.pyo
> /usr/share/applications/AccessGrid/NodeService-Debug.desktop
> /usr/share/applications/AccessGrid/NodeService.desktop
> Any ideas?
> Steve
> Steve Gallo
> Database Administrator
> smgallo at ccr.buffalo.edu
> Center for Computational Research
> University at Buffalo, The State University of New York
> 9 Norton Hall, Buffalo, NY 14260-1800
> 716-645-6500 x521
> "It is not the strongest of the species that survive, nor the most
> intelligent, but the one most responsive to change" - Charles Darwin
