[AG-TECH] Re: vic runtime error
Thomas D. Uram
turam at mcs.anl.gov
Tue Dec 14 13:35:53 CST 2004
Steve:
Are you able to use the camera in other applications? If so, it could be that the VfwWdm
mapper is set to an invalid selection. Try this:
- Run vic from the command-line. You'll find it in the following directory:
c:\Documents and Settings\Application Data\AccessGrid\local_services\VideoService
- In the menu, under Options, select "Configure on transmit"
- Hit the transmit button. You should get a list of devices from which to choose.
Set it to your camera, if you recognize it in the list; if not, try each of the settings
there.
This mapping is not managed in the AccessGrid code. If it's set incorrectly, vic will
crash whenever you try to use it.
Hope this helps,
Tom
Weidner, Steve wrote:
> I've installed AG 2.3 on a new laptop (3.2GHz / 1024M RAM) that will be
> a portable node for our campus. It includes a built-in camera just
> above the screen so aside from a headset, we should be able to
> participate in meetings without too much extra setup time in dealing
> with peripherals.
> Everything went perfectly in setup. I requested, received and installed
> an anonymous certificate and was able to jump right in to the venues
> server.
> When I started Node Management and added the VideoService, I received
> the runtime error listed below. I removed that service and tried each
> of the Video services in turn with the following results:
> - VideoConsumerService displays video as expected
> - Video ProducerService or VideoService both fail
> -- "Microsoft WDM Image Capture (Win32)" is the device being used
> -- both return the following error after opening a VIC window:
> |Runtime Error!
> |Program:
> ...a\AccessGrid\local_services\VideoProducerService\vic.exe
> |This application has requested the Runtime to terminate it in
> an
> |unususal way.
> |Please contact the applications's support team for more
> information.
> I hit "OK" and it closes the VIC window but leaves the pythonw.exe
> process running. If I remove the service, pythonw.exe will close.
> The system was rebooted after installation. (It is Windows, after
> all...)
> Any help would be greatly appreciated.
> Thanks,
> Steve Weidner
> ---Below is the tail-end of the VideoProducerService.log---
> 12/13/04 12:10:46 2360 Toolkit videoproducerservice.py:278 INFO
> Starting VideoProducerService
> 12/13/04 12:10:46 2360 Toolkit videoproducerservice.py:279 INFO
> executable = C:\Documents and Settings\USD AGNode\Application
> Data\AccessGrid\local_services\VideoProducerService\vic.exe
> 12/13/04 12:10:46 2360 Toolkit videoproducerservice.py:280 INFO
> options = ['-u',
> 'C:/DOCUME~1/USDAGN~1/LOCALS~1/Temp/VideoProducerService_3232.vic',
> '-C', '"Video"', '-t', '127', '224.2.177.155/55524']
> 12/13/04 12:10:46 2360 ProcessManager processmanager.py:59 DEBUG
> Creating process: C:\Documents and Settings\USD AGNode\Application
> Data\AccessGrid\local_services\VideoProducerService\vic.exe -u
> C:/DOCUME~1/USDAGN~1/LOCALS~1/Temp/VideoProducerService_3232.vic -C
> "Video" -t 127 224.2.177.155/55524
> 12/13/04 12:10:46 2360 ProcessManager processmanager.py:72 DEBUG
> Create process returns: (<PyHANDLE object at 0x010D539C>, <PyHANDLE
> object at 0x011EA0AC>, 228, 2216)
> 12/13/04 12:11:12 3280 Toolkit agservice.py:190 INFO Shut service
> down
> 12/13/04 12:11:12 3280 ProcessManager processmanager.py:135 ERROR
> couldn't shutdown process <PyHANDLE:716>: (1444, 'PostThreadMessage',
> 'Invalid thread identifier.')
> Traceback (most recent call last):
> File
> "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\ProcessManager.
> py", line 128, in TerminateProcess
> win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
> error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
> 12/13/04 12:11:12 3280 ProcessManager processmanager.py:142 ERROR
> couldn't terminate process <PyHANDLE:716>: (5, 'TerminateProcess',
> 'Access is denied.')
> File
> py", line 139, in TerminateProcess
> win32process.TerminateProcess(pid, 0)
> error: (5, 'TerminateProcess', 'Access is denied.')
> 12/13/04 12:11:12 1932 Hosting server.py:65 ERROR Exception in SOAP
> server main loop
> File
> "C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\Acc
> essGrid\hosting\SOAPpy\Server.py", line 63, in Run
> File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
> request, client_address = self.get_request()
> File
> "C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\SOA
> Ppy\GSIServer.py", line 140, in get_request
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
> get_request
> self.socket.listen()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in
> listen
> raise ex
> GSITCPSocketException: an I/O operation was cancelled
