[AG-TECH] AGTk/OSX default indentity/proxy problem
David McNabb
mcnabb at umd.edu
Fri Dec 10 08:20:30 CST 2004
Hello again AG'ers,
This is my second AGTk-on-OSX question and call for advice. As I mentioned earlier, I managed to mess up an apparently working installation of AGTk2.3 on a second G5 running OSX. I'm am not sure what I did, or this would surely be easier to figure out - sorry. Here's what I see:
The AG launcher comes up fine, as does the Venue Client. But as soon as I try to go to a venue I get the "No default identity is available" message, followed by the "You don't have a valid proxy. Please, try again" message.
Bringing up the Cert Mgr (from the Venue Client pref menu, of course) shows no certiicates present at all. I have 4 Trusted CA Certs, all valid, though issuer is "<self>" for three of them. When I try to import from my certificate .pem file (which worked fine the first time) I get this message:
"Certificate already exists
Another certificate with this name is already present.
Attempt to import anyway?"
Choosing Yes gives "Error on import... Certificate already in repository."
How can I clean this mess up? Thanks.
--David McNabb
