[AG-TECH] Fedora Core 3 Display Troubles
    Andrew Replogle
    andrew.replogle at gmail.com
    Thu Dec  9 22:52:21 CST 2004
Todd,
Try this site for a more in depth setup of X11 dual-headed:
http://quark.humbug.org.au/publications/xfree86/xinerama.html
Let me know if you still run into issues.
Andrew
On Thu, 9 Dec 2004 15:52:36 -0600, Todd Reed <treed at astate.edu> wrote:
> I've installed Fedora Core 3 on our Display System and I'm having
> trouble getting the displays to span across the screens.  I have the
> operators monitor plugged into a Matrox G200.  There are also 3
> Projectors plugged into a Matrox G450.  The G200 works fine and the G450
> is being recoginized by Fedora.  However, I'm getting a "No Signal"
> message on the projectors.  I've tried going into the Display Setting,
> Use Dual head, Second Video Card = G450, Desktop Layout = Spanning.  But
> nithing happens.  The other odd issue is that there are 4 - G200 in the
> Second Video Card section and 1 G450.
> Any suggestions to make this work?
> --Todd
