[AG-TECH] BridgeServer problems
Fred Dech fdech at uchicago.edu
Mon Aug 23 10:44:51 CDT 2004
howdy.
on and off i've been testing a BridgeServer with a VenueServer i have
running.  both servers are running on the same machine for the tests. the
machine is Fedora core2 linux running well behaved AG2.3beta.
before i start the BridgeServer, my VenueServer works well.  after i start
the BridgeServer that is pointing at my VenueServer, the VenueServer ceases
to start services properly.  if i start a VenueClient and go to my bridge-
enabled VenueServer's virtual venues, neither RAT nor VIC will fire up.
my BridgeServer complains:
using multicast
ucport[data]=46238  ucport[rtcp]=46239
mcport[data]=59936  mcport[rtcp]=59937
making multicast port[0]
making multicast port[1]
No bridge.acl file found, no ACL set
my VenueClient complains:
resource defaultTTL Vic
bind: Address already in use
rat-4.2.22-media: main_engine.c:200: rendezvous_with_controller: Assertion `sp[i]->rtp_session[0] != ((void *)0)' failed.
as soon as i kill the BridgeServer and re-connect to the VenueServer with a
VenueClient, all of the services come up fine.
i'm sure that it is a good idea to run both a VenueServer and its
BridgeServer on the same machine.  i only have 1 good FC2 machine at the
moment.
are both servers competing for the same IO ports?
thanks.
--fred
More information about the ag-tech mailing list
