[AG-TECH] CVS AGTk client cannot connect to default server (RH9.0)
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Aug 18 22:15:09 CDT 2004
The 'xio' here indicates that post-2.4.3 globus was used.  AG 2.x relies
on globus 2.4.3, so if you install that and build pyGlobus against it,
this problem will be resolved.
Tom
 > GSITCPSocketException: globus_xio_gsi: gss_init_sec_context failed.
Socrates Varakliotis wrote:
> Dear All:
> I installed the cvs version of the AGTk on RH9.0.
> I also requested and was issued with a valid certificate, which I
> imported successfully. After launching the Venu Client with:
> prompt> python2.3 AccessGrid/bin/VenueClient.py --debug
> I cannot connect to the default venue at ANL. The output on the screen
> follows. The client's log file is also attached.
> Any help appreciated.
> Best Regards,
> 18/08/04 16:14:11 1074896032 Platform     Config.py:341 DEBUG retrieved local IP address 128.16.66.76
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:263 DEBUG Opened repository /root/.AccessGrid/Config/certRepo
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:729 DEBUG Configuring standard environment
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:797 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:868 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:887 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:890 DEBUG Proxy /tmp/x509up_u0 will expire 18/08/04 20:27:23
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:293 DEBUG __StartWebService: venueclient: https://128.16.66.76:64182/VenueClient
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:191 DEBUG __createPersonalDataStore: Creating personal datastore at /root/.AccessGrid/Config/personalDataStore using prefix personalDataStore and port 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1512 DEBUG Creating thread 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1517 DEBUG Starting thread 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1519 DEBUG Waiting thread 0
> 18/08/04 16:14:11 1142135600 DataStore     DataStore.py:1525 DEBUG Worker 0 starting
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1522 DEBUG Done creating workers
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:270 DEBUG Reading persisted data from: /root/.AccessGrid/Config/personalDataStore/DataStore.dat
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:216 DEBUG __createPersonalDataStore: Load personal data from file
> 18/08/04 16:14:11 1074896032 VenueClientController     VenueClientController.py:1343 DEBUG There is no personal venues file to load.
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:802 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> 18/08/04 16:14:18 1074896032 CertificateManager     CertificateManager.py:633 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2/CN=proxy
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:825 INFO  EnterVenue: Error getting node capabilities
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:700 DEBUG EnterVenue: Invoke venue enter
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:667 ERROR SOAP fault occurred
> Traceback (most recent call last):
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 347, in __call
>     config = self.config)
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 187, in call
>     r.endheaders()
>   File "/usr/local/lib/python2.3/httplib.py", line 712, in endheaders
>     self._send_output()
>   File "/usr/local/lib/python2.3/httplib.py", line 597, in _send_output
>     self.send(msg)
>   File "/usr/local/lib/python2.3/httplib.py", line 564, in send
>     self.connect()
>   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 1425, in connect
>     self.sock.connect(self.host, self.port, self.io_attr)
>   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 988, in connect
>     raise ex
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:846 ERROR EnterVenue: globus tcp exception: ('globus_xio_gsi: gss_init_sec_context failed.',)
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:853 ERROR EnterVenue: failed
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/VenueClient.py", line 829, in EnterVenue
>     self.__EnterVenue(URL)
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/VenueClient.py", line 701, in __EnterVenue
>     (venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/Venue.py", line 3339, in Enter
>     (r1, r2, r3) = self.proxy.Enter(profile)
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 453, in __call__
>     return self.__r_call(*args, **kw)
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 475, in __r_call
>     self.__hd, self.__ma)
>     r.endheaders()
>     self._send_output()
>     self.send(msg)
>     self.connect()
>     raise ex
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2054 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2067 DEBUG warningString:
> 18/08/04 16:14:28 1074896032 VenueClient     VenueClientUI.py:1701 INFO  --------- END VenueClient
> 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1530 DEBUG Worker 0 gets cmd quit
> 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1543 DEBUG Worker 0 exiting
> 18/08/04 16:14:28 1150528304 DataStore     DataStore.py:1603 ERROR Exception handling request
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/DataStore.py", line 1599, in thread_run
>     self.handle_request()
>   File "/usr/local/lib/python2.3/SocketServer.py", line 217, in handle_request
>     request, client_address = self.get_request()
>   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 843, in get_request
>     raise(str(self.socket) + str(" is having trouble listening!:" + str(ex.args)))
> <pyGlobus.io.GSITCPSocket instance at 0x41de94ec> is having trouble listening!:('an I/O operation was cancelled',)
> 18/08/04 16:14:28 1133742896 Hosting     Server.py:65 ERROR Exception in SOAP server main loop
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/hosting/SOAPpy/Server.py", line 63, in Run
>     self._server.handle_request()
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/GSIServer.py", line 140, in get_request
>     sock, addr = ThreadingGSITCPSocketServer.get_request(self)
> <pyGlobus.io.GSITCPSocket instance at 0x41de908c> is having trouble listening!:('an I/O operation was cancelled',)
