[AG-TECH] CVS AGTk client cannot connect to default server (RH9.0)
    Jerome
    jeremy.knope at gmail.com
    Wed Aug 18 18:27:09 CDT 2004
I've had that problem also i think, but was from a AccessGrid 2.2
installation on a RH9 machine, that decided to stop working like
that... not sure what it was because it was working not long before...
wish i could give you a solution tho but i ended up taking out my
frustration on the machine by killing RH9 and replacing it with
gentoo... but there definitely is something funny with RH9(maybe) and
something going wrong after some use in AG
 --jerome
On Wed, 18 Aug 2004 16:26:00 +0100, Socrates Varakliotis
<s.varakliotis at cs.ucl.ac.uk> wrote:
> Dear All:
> I installed the cvs version of the AGTk on RH9.0.
> I also requested and was issued with a valid certificate, which I
> imported successfully. After launching the Venu Client with:
> prompt> python2.3 AccessGrid/bin/VenueClient.py --debug
> I cannot connect to the default venue at ANL. The output on the screen
> follows. The client's log file is also attached.
> Any help appreciated.
> Best Regards,
> Dr. Socrates Varakliotis
> UCL Computer Science
> Gower Street, WC1E 6BT, London, UK
> Tel: +44 20 7679 3696
> Fax: +44 20 7387 1397
> [root at Gorilla agtk-cvs]# python AccessGrid/bin/VenueClient.py --debug &
> [1] 7568
> [root at Gorilla agtk-cvs]# 18/08/04 16:14:11 1074896032 Toolkit
> Toolkit.py:121 INFO  Logfile Name: VenueClient.log
> 18/08/04 16:14:10 1074896032 ProxyGen     ProxyGen.py:567 DEBUG Using
> GT24 proxy code
> 18/08/04 16:14:11 1074896032 Toolkit     Toolkit.py:79 DEBUG
> Initializing AG Toolkit version 2.3
> 18/08/04 16:14:11 1074896032 Platform     Config.py:1050 INFO  gnome
> directory /root/.gnome/application-info or /root/.gnome/mime-info not
> found, not registering file type .agpkg with gnome
> found, not registering file type .vv2d with gnome
> 18/08/04 16:14:11 1074896032 Toolkit     Toolkit.py:121 INFO  Logfile
> 18/08/04 16:14:11 1074896032 Platform     Config.py:341 DEBUG retrieved
> local IP address 128.16.66.76
> 18/08/04 16:14:11 1074896032 CertificateManager
> CertificateManager.py:263 DEBUG Opened repository
> /root/.AccessGrid/Config/certRepo
> CertificateManager.py:729 DEBUG Configuring standard environment
> CertificateManager.py:797 DEBUG Using default identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
> CertificateManager.py:868 DEBUG Initializing environment with proxy cert
> for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates
> Varakliotis2
> CertificateManager.py:887 DEBUG Configuring for user proxy issued from
> Varakliotis2
> CertificateManager.py:890 DEBUG Proxy /tmp/x509up_u0 will expire
> 18/08/04 20:27:23
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:293 DEBUG
> __StartWebService: venueclient: https://128.16.66.76:64182/VenueClient
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:191 DEBUG
> __createPersonalDataStore: Creating personal datastore at
> /root/.AccessGrid/Config/personalDataStore using prefix
> personalDataStore and port 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1512 DEBUG
> Creating thread 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1517 DEBUG
> Starting thread 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1519 DEBUG
> Waiting thread 0
> 18/08/04 16:14:11 1142135600 DataStore     DataStore.py:1525 DEBUG
> Worker 0 starting
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1522 DEBUG Done
> creating workers
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:270 DEBUG
> Reading persisted data from:
> /root/.AccessGrid/Config/personalDataStore/DataStore.dat
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:216 DEBUG
> __createPersonalDataStore: Load personal data from file
> 18/08/04 16:14:11 1074896032 VenueClientController
> VenueClientController.py:1343 DEBUG There is no personal venues file to
> load.
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:802 DEBUG
> EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> 18/08/04 16:14:18 1074896032 CertificateManager
> CertificateManager.py:633 DEBUG HaveValidProxy: found proxy ident
> Varakliotis2/CN=proxy
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:825 INFO
> EnterVenue: Error getting node capabilities
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:700 DEBUG
> EnterVenue: Invoke venue enter
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:667 ERROR
> SOAP fault occurred
> Traceback (most recent call last):
>    File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line
> 347, in __call
>      config = self.config)
> 187, in call
>      r.endheaders()
>    File "/usr/local/lib/python2.3/httplib.py", line 712, in endheaders
>      self._send_output()
>    File "/usr/local/lib/python2.3/httplib.py", line 597, in _send_output
>      self.send(msg)
>    File "/usr/local/lib/python2.3/httplib.py", line 564, in send
>      self.connect()
>    File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line
> 1425, in connect
>      self.sock.connect(self.host, self.port, self.io_attr)
> 988, in connect
>      raise ex
> GSITCPSocketException: globus_xio_gsi: gss_init_sec_context failed.
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:846 ERROR
> EnterVenue: globus tcp exception: ('globus_xio_gsi: gss_init_sec_context
> failed.',)
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:853 ERROR
> EnterVenue: failed
>    File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/VenueClient.py",
> line 829, in EnterVenue
>      self.__EnterVenue(URL)
> line 701, in __EnterVenue
>      (venueState, self.privateId, self.streamDescList ) =
> self.__venueProxy.Enter( self.profile )
>    File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/Venue.py", line
> 3339, in Enter
>      (r1, r2, r3) = self.proxy.Enter(profile)
> 453, in __call__
>      return self.__r_call(*args, **kw)
> 475, in __r_call
>      self.__hd, self.__ma)
> 347, in __call
> 187, in call
>      r.endheaders()
>      self._send_output()
>      self.send(msg)
>      self.connect()
> 1425, in connect
> 988, in connect
>      raise ex
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2054 DEBUG
> bin.VenueClient::EnterVenue: Enter venue with url:
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2067 DEBUG
> warningString:
> 18/08/04 16:14:28 1074896032 VenueClient     VenueClientUI.py:1701 INFO
>   --------- END VenueClient
> 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1530 DEBUG
> Worker 0 gets cmd quit
> 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1543 DEBUG
> Worker 0 exiting
> 18/08/04 16:14:28 1150528304 DataStore     DataStore.py:1603 ERROR
> Exception handling request
>    File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/DataStore.py",
> line 1599, in thread_run
>      self.handle_request()
>    File "/usr/local/lib/python2.3/SocketServer.py", line 217, in
> handle_request
>      request, client_address = self.get_request()
> 843, in get_request
>      raise(str(self.socket) + str(" is having trouble listening!:" +
> str(ex.args)))
> <pyGlobus.io.GSITCPSocket instance at 0x41de94ec> is having trouble
> listening!:('an I/O operation was cancelled',)
> 18/08/04 16:14:28 1133742896 Hosting     Server.py:65 ERROR Exception in
> SOAP server main loop
>    File
> "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/hosting/SOAPpy/Server.py",
> line 63, in Run
>      self._server.handle_request()
> handle_request
>    File "/usr/local/lib/python2.3/site-packages/SOAPpy/GSIServer.py",
> line 140, in get_request
>      sock, addr = ThreadingGSITCPSocketServer.get_request(self)
> 843, in get_request
> str(ex.args)))
> <pyGlobus.io.GSITCPSocket instance at 0x41de908c> is having trouble
> 18/08/04 16:14:11 1074896032 Platform     Config.py:341 DEBUG retrieved local IP address 128.16.66.76
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:263 DEBUG Opened repository /root/.AccessGrid/Config/certRepo
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:729 DEBUG Configuring standard environment
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:797 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:868 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:887 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2
> 18/08/04 16:14:11 1074896032 CertificateManager     CertificateManager.py:890 DEBUG Proxy /tmp/x509up_u0 will expire 18/08/04 20:27:23
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:293 DEBUG __StartWebService: venueclient: https://128.16.66.76:64182/VenueClient
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:191 DEBUG __createPersonalDataStore: Creating personal datastore at /root/.AccessGrid/Config/personalDataStore using prefix personalDataStore and port 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1512 DEBUG Creating thread 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1517 DEBUG Starting thread 0
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1519 DEBUG Waiting thread 0
> 18/08/04 16:14:11 1142135600 DataStore     DataStore.py:1525 DEBUG Worker 0 starting
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:1522 DEBUG Done creating workers
> 18/08/04 16:14:11 1074896032 DataStore     DataStore.py:270 DEBUG Reading persisted data from: /root/.AccessGrid/Config/personalDataStore/DataStore.dat
> 18/08/04 16:14:11 1074896032 VenueClient     VenueClient.py:216 DEBUG __createPersonalDataStore: Load personal data from file
> 18/08/04 16:14:11 1074896032 VenueClientController     VenueClientController.py:1343 DEBUG There is no personal venues file to load.
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:802 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> 18/08/04 16:14:18 1074896032 CertificateManager     CertificateManager.py:633 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.ucl.ac.uk/CN=Socrates Varakliotis2/CN=proxy
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:825 INFO  EnterVenue: Error getting node capabilities
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:700 DEBUG EnterVenue: Invoke venue enter
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:667 ERROR SOAP fault occurred
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 347, in __call
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 187, in call
>     r.endheaders()
>     self._send_output()
>     self.send(msg)
>     self.connect()
>   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 1425, in connect
>   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 988, in connect
>     raise ex
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:846 ERROR EnterVenue: globus tcp exception: ('globus_xio_gsi: gss_init_sec_context failed.',)
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClient.py:853 ERROR EnterVenue: failed
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/VenueClient.py", line 829, in EnterVenue
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/VenueClient.py", line 701, in __EnterVenue
>     (venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/Venue.py", line 3339, in Enter
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 453, in __call__
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/Client.py", line 475, in __r_call
>     r.endheaders()
>     self._send_output()
>     self.send(msg)
>     self.connect()
>     raise ex
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2054 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
> 18/08/04 16:14:18 1074896032 VenueClient     VenueClientUI.py:2067 DEBUG warningString:
> 18/08/04 16:14:28 1074896032 VenueClient     VenueClientUI.py:1701 INFO  --------- END VenueClient
> 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1530 DEBUG Worker 0 gets cmd quit
> 18/08/04 16:14:28 1142135600 DataStore     DataStore.py:1543 DEBUG Worker 0 exiting
> 18/08/04 16:14:28 1150528304 DataStore     DataStore.py:1603 ERROR Exception handling request
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/DataStore.py", line 1599, in thread_run
>   File "/usr/local/lib/python2.3/SocketServer.py", line 217, in handle_request
>   File "/usr/local/lib/python2.3/site-packages/pyGlobus/io.py", line 843, in get_request
>     raise(str(self.socket) + str(" is having trouble listening!:" + str(ex.args)))
> <pyGlobus.io.GSITCPSocket instance at 0x41de94ec> is having trouble listening!:('an I/O operation was cancelled',)
> 18/08/04 16:14:28 1133742896 Hosting     Server.py:65 ERROR Exception in SOAP server main loop
>   File "/home/ucacsva/agtk-cvs/AccessGrid/AccessGrid/hosting/SOAPpy/Server.py", line 63, in Run
>   File "/usr/local/lib/python2.3/site-packages/SOAPpy/GSIServer.py", line 140, in get_request
> <pyGlobus.io.GSITCPSocket instance at 0x41de908c> is having trouble listening!:('an I/O operation was cancelled',)
