[AG-TECH] 2.2 video problems.
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Aug 17 20:22:29 CDT 2004
Hi Vic,
> So I can force vic to show my video streams, but I still can't get the
> NodeSetupWizard to acknowledge them...
> Here's what I did...
> I started AGServiceManager (attached AGS2.OUT output)
> Then I started the NodeSetupWizard (attached NODES.OUT) which again only
> showed x11 as a video source.
> So I started up the Venue Client and then started an AGNodeService
instance
> (AGN.OUT). Adding the localhost as a service manager and adding a
> VideoConsumer service along with a VideoProducer service (again only x11
> visible), I then see ~.AccessGrid/local_services/VideoConsumerService and
> VideoProducerService.
> I initiate vic using ./vic localhost/1283 (VIC2.OUT) I then manipulate
the
> port and device and lo and behold I see my video feed.
> So, did I find a bug? What do I win? Can I win a fix if I can't create
> one?
Snippet from your attached AGServiceManager log file:
08/17/04 11:17:43 1075394784 Platform Config.py:670 INFO /proc/video/dev
does not exist; no video devices detected
It's a bug with AGTk 2.2, /proc/video/dev does not exist, which is typically
because kernel 2.6/V4L2 is being used.
The fix is to use AGTk 2.3 Beta1 or modify the following file:
/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py
(it might be located in the python2.2 site-packages directory instead)
The modification involves replacing the GetResources function with the
version from CVS's Config.py:
http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/AccessGrid/AccessGrid/Platform/unix/
Then add the following import lines somewhere in the top of Config.py:
import fcntl
import glob
import struct
CVS (and 2.3 Beta1) also has version's of VideoProducerService.py and
VideoService.py which fixes issues with S-Video port selection.
Cheers,
Doug
