[AG-TECH] 2.2 video problems.
Victor M. Babson, Jr.
vbabson at secsg.uga.edu
Tue Aug 17 10:41:36 CDT 2004
Doug,
Thanks for the response. It gave me some ideas...
Okay everyone,
So I can force vic to show my video streams, but I still can't get the
NodeSetupWizard to acknowledge them...
Here's what I did...
I started AGServiceManager (attached AGS2.OUT output)
Then I started the NodeSetupWizard (attached NODES.OUT) which again only
showed x11 as a video source.
So I started up the Venue Client and then started an AGNodeService instance
(AGN.OUT). Adding the localhost as a service manager and adding a
VideoConsumer service along with a VideoProducer service (again only x11
visible), I then see ~.AccessGrid/local_services/VideoConsumerService and
VideoProducerService.
I initiate vic using ./vic localhost/1283 (VIC2.OUT) I then manipulate the
port and device and lo and behold I see my video feed.
So, did I find a bug? What do I win? Can I win a fix if I can't create
one?
--Vic
----- Original Message -----
From: "Douglas Kosovic" <douglask at itee.uq.edu.au>
To: <ag-tech at mcs.anl.gov>
Sent: Sunday, August 15, 2004 9:06 PM
Subject: Re: [AG-TECH] 2.2 video problems.
> Hi Vic,
> > So I had this linux box with 2.1.2 working just fine.
> > Now that I have removed 2.1.2 and installed 2.2 I can't seem to get
> > any video feed working. I installed xawtv (wasn't installed for
> > 2.1.2 -- but v4l2 was).
> > When running a prog like xcam, I can see my video feed just fine.
> > When I try using xawtv, however, I get a blank screen. I've tried
> > xawtv 3.54 to 3.93.
> It would be better to test it with vic, which can be found in a subdir of
> ~/.AccessGrid/local_services/ , assuming you've enabled at least one of
the
> Video Services in AGTk.
> Only v4lctl is used from xawtv, you could try the following to see if it
> detects the input ports:
> /usr/bin/v4lctl -c /dev/video0 list
> > I've seen some posts that say I should edit the videopath in
> > /usr/lib/python2.2/site-packages/AccessGrid/Platform/unix/Config.py
> > to point to /dev instead of /proc/video/dev. I've done this, but it
> > just makes the x11 feed disappear.
> You might want to have a look at the following log:
> ~/.AccessGrid/Logs/ServiceManager.log
> or use the --debug switch with ServiceManager.py to see if there is any
> useful diagnostic info.
> The V4L devices might be busy (i.e. you have other applications accessing
> the V4L devices) when the ServiceManager tries to interogate them for
their
> input ports.
> Cheers,
> Doug
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040817/9b247088/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040817/9b247088/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040817/9b247088/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040817/9b247088/attachment-0003.obj>
