[AG-TECH] Ospreys & FC2
Stuart Poulton
swp at astro.le.ac.uk
Tue Aug 17 03:33:17 CDT 2004
Hi Doug,
After a bit of hacking (removing KDE stuff from Config.py)... I can get
the venuclient to run.
Howeve I can still only get video on the 2, 220's the 2, 230's don't
have anything at all.
I suspect that there is an issue with the PCI bus and FC2 which is
preventing this from working correctly.
Regards
Stuart
On Aug 17, 2004 04:39 AM, Douglas Kosovic <douglask at itee.uq.edu.au>
wrote:
> Hi Stuart,
> > It's never easy is it. Having made little progress in getting my 4
> > osprey cards to work with AG2.2 under windows XP, I moved to FC2
> > Great all 4 cards are there, however I can only get streams from the
> > S-Video input on the 2 Osprey 220's , I'm unable to change inputs on
> > the
> > 2 230's.
> Download the following V4L python script:
> http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/patches/v4ltest.py
> then run it (either chmod a+rx it or python v4ltest.py), if it doesn't
> detects all the inputs on Osprey 230s, let me know what v4ltest.py's
> output
> is.
> If the v4ltest.py script detects all the inputs of the video cards you
> have
> installed, replace the existing Config.py located at:
> /usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py
> with the new Config.py from:
> http://www.itee.uq.edu.au/~agn/ag_fedora/FC2/stable/patches/Config.py
> As root run:
> python
> which will compile Config.py to Config.pyc, ignore any output
> messages.
> You can then start AGServiceManager.py as you normally do...
> Cheers,
> Doug
