[AG-TECH] VIC problem, not remembering which device
    Doiron, Andre
    Andre.Doiron at nrc-cnrc.gc.ca
    Thu Aug 12 13:06:16 CDT 2004
You're running the capture devices on windows then... I'm sorry but I can't
help you there, I only have experience with the capture devices running on a
Linux machine.
Good luck,
André Doiron
NRC - CNRC
55 Crowley Farm
Moncton, New Brunswick
-----Original Message-----
From: Benedikt Bjarni Bogason [mailto:benedib at hi.is]
Sent: August 12, 2004 3:00 PM
To: Doiron, Andre
Cc: ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] VIC problem, not remembering which device
Unfortunatly there is no option there to select cameras (not in 2.2, there
is one in 2.1.2). Only thing I could configure is "port:" in which field i
wrote "external-in" as that is how it is in my 2.1.2 settings (although
there it is on a dropdown menu.)
Benedikt.
> Hello Benedikt,
> 	After you add the VideoProducers (in the node manager) right click
> on these entries under the Services list. And select configure. Set the
> camera you would like to use. Close that window, now in the Node Manager
> save the configuration so that the cameras settings are saved and loaded
> next time.
> Hope this helps,
> André Doiron
> NRC - CNRC
> 55 Crowley Farm
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf
> Of Benedikt Bjarni Bogason
> Sent: August 12, 2004 1:19 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] VIC problem, not remembering which device
> Hello.
> I'm trying to configure VIC. This is a room node, that has been running
> AG2.1 handling 3 cameras (actually only 2 successfully, but that is
> another matter).
> I've set up AG2.2 along side it, and it has worked "ok". Main problem is
> that I can't make VIC understand that I have two cameras (actually 3, but
> I will settle for two, as that is what the older version managed to
> handle.)
> I add 3 instances of VideoProducer and one VideoConsumer. Save the
> settings as default. No problem. Then I hit Menu on those VICs to assign
> each one their own camera, which is no problem. But when I exit the venue,
> and go to a new venue, the vics have forgotten those instructions and all
> broadcast from the same camera.
> How can I configure it so they don't act so foolishly?
> Regards,
> Benedikt.
