[AG-TECH] AG2.2 - Venue Client
    Anne M. Hammond
    hammond at solarz.Colorado.EDU
    Thu Aug 12 15:57:39 CDT 2004
John Q.
What is the "existing hack" to get around the problem with the
video cards?  My UK colleague is here until Friday and we are
trying to get his VAIO to work.  He installed 2.3 yesterday
and Vic comes up, but we are not sending video.
Anne
Anne M. Hammond                    Anne.Hammond at Colorado.EDU
UNIX Systems Mgmt                  303-492-5578  (FAX -5235)
Laboratory for Computational Dynamics (LCD)
JILA / University of Colorado at Boulder
Boulder, CO 80309-0440
>Mime-Version: 1.0 (Apple Message framework v619)
>Cc: <turam at mcs.anl.gov>, "Anne M. Hammond" <hammond at solarz.Colorado.EDU>,
ag-tech at mcs.anl.gov
>From: John I Quebedeaux Jr <johnq at lsu.edu>
>Subject: Re: [AG-TECH] AG2.2 - Venue Client
>Date: Thu, 12 Aug 2004 13:44:39 -0500
>To: Monika Rabarison <monika.k.rabarison at ccaix.jsums.edu>
>Content-Transfer-Encoding: 7bit
>X-Spam-Checker-Version: SpamAssassin 2.63 (2004-01-11) on lcd.colorado.edu
>X-Spam-Level: *
>X-Spam-Status: No, hits=1.9 required=5.0 tests=WEIRD_PORT autolearn=no
version=2.63
>I've installed 2.3beta version (all XP) and don't seem to have a
>problem except for: video cards not being recognized (ospreys - works
>with 2.1.2) and the bug regarding saving the node configuration (used
>the existing one which works). Used the existing hack to get around the
>problem for now with the video cards.
>I have yet to try all the shared apps though - working through things...
>-John Q.
>John I. Quebedeaux, Jr.
>Louisiana State University
>Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339 Johnston
>Hall
>e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web: http://lbrn.lsu.edu &
>http://cct.lsu.edu
>phone: 225-578-0062 / fax: 225-578-2597
>On Aug 12, 2004, at 8:41 AM, Monika Rabarison wrote:
>> Anne,
>> I just installed 2.3 on XP yesterday, without any problem.
>> I am wondering if you got a certificate or not.
>> Monika
>> On Wed, 11 Aug 2004, Anne M. Hammond wrote:
>>> I just installed AGTk2.3 on a brand new WinXP laptop with no previous
>>> AGTk installation.  I installed the required Active Python and
>>> wxPython first.
>>> I am having the same issues as with 2.2.  Does not bring up RAT
>>> or Vic.  Menu Preferences / Manage My Node
>>>     brings up the "Set Node Service URL"
>>>     OK brings up Node Management Error (cannot open node management)
>>>     Cancel does nothing.
>>> Both Audio and Video are enabled in the menu.
>>> Is this a security/permissions issue, rather than incompatibility
>>> between versions??
>>> TIA.
>>>>> - Start the VenueClient
>>>>> - Select Preferences->ManageMyNode
>>>>>      OK produces the error listed below
>>>>>      Cancel brings up nothing.
>>>>> - Add the service manager at localhost 11000
>>>>> - Add services (audio, videoconsumer, videoproducer) to the service
>>>>> manager
>>>>> - Save the node config as the default
>>>>>> From Windows Menu:
>>>>> Venue Client
>>>>> Access Grid Toolkit 2.2
>>>>>  Configure
>>>>>    Node Management
>>>>>    Add ServiceManager  (add localhost port 11000)
>>>>>    Window:  Message
>>>>>             Service Manager is unreachable
>>>>> (https://jil-188-dhcp17.Colorado.EDU:11000/ServiceManager)
>>>>>    Then it will bring up the menu to Add the services.  It I click
>>>>> on
>>>>>    a service/OK, it doesn't add it to the ServiceName list.
>>>>>> Date: Wed, 11 Aug 2004 14:21:07 -0500
>>>>>> From: Thomas Uram <turam at mcs.anl.gov>
>>>>>> User-Agent: Mozilla Thunderbird 0.7.3 (Windows/20040803)
>>>>>> X-Accept-Language: en-us, en
>>>>>> MIME-Version: 1.0
>>>>>> To: "Anne M. Hammond" <hammond at solarz.Colorado.EDU>
>>>>>> lcd.colorado.edu
>>>>>> X-Spam-Level: *
>>>>>> autolearn=no
>>>>> version=2.63
>>>>>> You should not set the node service url.  Just select ManageMyNode
>>>>>> and
>>>>>> then do the steps I listed earlier.  Let me know if you run into
>>>>>> problems.
>>>>>> Tom
>>>>>>> Yes.  I start the Venue Client from the Windows menu.
>>>>>>> Then set Service Node URL by clicking OK.
>>>>>>> The next thing that comes up is a window:
>>>>>>> Can not open node management
>>>>>>> at https://jil-188-dhcp17.Colorado.EDU:11000/NodeService
>>>>>>>> Date: Wed, 11 Aug 2004 14:01:51 -0500
>>>>>>>> MIME-Version: 1.0
>>>>>>>> lcd.colorado.edu
>>>>>>>> X-Spam-Level: *
>>>>>>>> autolearn=no
>>>>>>> version=2.63
>>>>>>>> How did you start the venue client?  From the menu?
>>>>>>>>> service
>>> manager
>>>>>>>>> I started this.  But there is an error message after Step 3.
>>>>>>>>> Actually it is not localhost but
>>>>>>>>> Set node service URL
>>>>>>>>> Please, specify node service URL
>>>>>>>>> Address: https://jil-188-dhcp17.Colorado.EDU:11000/NodeService
>>>>>>>>> Click OK
>>>>>>>>> then pop up
>>>>>>>>> at https://jil-188-dhcp17.Colorado.EDU:1100/NodeService
>>>>>>>>>> Date: Wed, 11 Aug 2004 13:26:12 -0500
>>>>>>>>>> MIME-Version: 1.0
>>> lcd.colorado.edu
>>>>>>>>>> X-Spam-Level:
>>>>>>>>>> X-Spam-Status: No, hits=0.0 required=5.0 tests=none
>>>>>>>>>> autolearn=no
>>>>> version=2.63
>>>>>>>>>> Did you go through the steps I mentioned?  You shouldn't have
>>>>>>>>>> to
>>>>>>>>>> reinstall to recover from this problem, just build a new node
>>>>> configuration.
>>>>>>>>>> Michael Braitmaier's suggestion is not suitable for the way
>>>>>>>>>> you're
>>>>>>>>>> running the software, so you should ignore that advice.
>>>>>>>>>> Tom
>>>>>>>>>>> I submitted a bug.
>>>>>>>>>>> I also tried creating a zero length defaultWindows file.  The
>>>>>>>>>>> debug output is in the bug submission.
>>>>>>>>>>> What about uninstalling 2.2, mving c:\. . .\Application
>>>>>>>>>>> Data\AccessGrid
>>>>>>>>>>> aside and just reinstalling 2.2, then mv'ing the certificates
>>>>>>>>>>> back.
>>>>>>>>>>> Anne
>>>>>>>>>>>> Date: Wed, 11 Aug 2004 12:29:12 -0500
>>>>>>>>>>>> MIME-Version: 1.0
>>>>> lcd.colorado.edu
>>>>>>>>>>>> X-Spam-Level:
>>>>>>>>>>>> autolearn=no
>>>>>>> version=2.63
>>>>>>>>>>>> Yes, that's probably a good idea.  If you're sending large
>>>>>>>>>>>> logfiles or
>>>>>>>>>>>> such, you can send them to me separately, or put them on the
>>>>>>>>>>>> web
>>>>>>>>>>>> somewhere and send the link.
>>>>>>>>>>>> Tom
>>>>>>>>>>>>> Thanks Tom.  Should I cc the list on any correspondence?
>>>>>>>>>>>>> Anne Hammond
>>>>>>>>>>>>> U of Colorado at Boulder
>>>>>>>>>>>>>> Date: Wed, 11 Aug 2004 08:48:29 -0500
>>>>>>>>>>>>>> MIME-Version: 1.0
>>>>>>>>>>>>>> CC: ag-tech at mcs.anl.gov
>>>>>>> lcd.colorado.edu
>>>>>>>>>>>>>> X-Spam-Level:
>>>>>>>>>>>>>> autolearn=no
>>>>>>>>> version=2.63
>>>>>>>>>>>>>> X-Keywords:
>>>>>>>>>>>>>> Hi Anne:
>>>>>>>>>>>>>> The error you identified shouldn't prevent the node setup
>>>>>>>>>>>>>> wizard from
>>>>>>>>>>>>>> starting.  There should be another indication of problem
>>>>>>>>>>>>>> in that
>>>>>>>>>>>>>> logfile; if you don't see it, you should file a bug for
>>>>>>>>>>>>>> the node
>>> setup
>>>>>>>>>>>>>> wizard in our bugzilla
>>>>>>>>>>>>>> (http://bugzilla.mcs.anl.gov/AccessGrid) and
>>>>>>>>>>>>>> include the logfile.
>>>>>>>>>>>>>> The problem you encountered with rat and vic not starting
>>>>>>>>>>>>>> is due to a
>>>>>>>>>>>>>> difference in the personal node setup between 2.1 and 2.2.
>>>>>>>>>>>>>>  You
>>> should
>>>>>>>>>>>>>> be able to get the media tools working by building a new
>>>>>>>>>>>>>> node
>>>>>>>>> configuration:
>>>>>>>>>>>>>> the service
>>>>>>> manager
>>>>>>>>>>>>>> It should then work each time you start the venue client.
>>>>>>>>>>>>>> Tom
>>>>>>>>>>>>>>> I had installed AG2.2, after installing ActiveState
>>>>>>>>>>>>>>> Active Python
>>> 2.3
>>>>>>>>>>>>>>> and wxPython 2.4 for Python 2.3.
>>>>>>>>>>>>>>> I am using an IBM ThinkPad with a Logitech camera (which
>>>>>>>>>>>>>>> works).
>>>>>>>>>>>>>>> When I bring up the Venue Client, the Rat and Vic
>>>>>>>>>>>>>>> thumbnails do not
>>>>>>>>>>>>>>> come up.  Audio and Video are enabled.
>>>>>>>>>>>>>>> I tried twice to start the Node Setup Wizard.  It gets
>>>>>>>>>>>>>>> 80% into
>>>>>>>>>>>>>>> the green startup bar, and then gives a messages that it
>>>>>>>>>>>>>>> cannot
>>>>>>>>>>>>>>> start the Wizard.
>>>>>>>>>>>>>>> I have run the Venue Client in debug mode.  The first
>>>>>>>>>>>>>>> ERROR is
>>>>>>>>>>>>>>> venueclient.py:317 ERROR Error loading default
>>>>>>>>>>>>>>> configuration.
>>>>>>>>>>>>>>> Is there a way to troubleshoot this, or do I need to fall
>>>>>>>>>>>>>>> back to
>>>>>>>>>>>>>>> AG2.1?  If I need to fall back, do I need to get the
>>>>>>>>>>>>>>> older versions
>>>>>>>>>>>>>>> of Active Python and wxPython??
>>>>>>>>>>>>>>> Thanks in advance.
>>>>>>>>>>>>>>> Anne Hammond
>> Monika Rabarison
>> Systems Administrator
>> Information Technology/HPCVI
>> Jackson State University
>> Office:(601)979-5933
>> SciVis Lab:(601)979-1061
>> JSUvisNode:(601)979-1056
>> JSUeNode:(601)979-1081
