[AG-TECH] AGTk 2.3 BETA Released
    Randy Groves
    randy.groves at boeing.com
    Mon Aug  9 18:12:41 CDT 2004
I didn't have to include a configfile parameter and didn't get the errors
that you saw.  I ran VenueServer.py as 'ag' which is a normal user - and
ran it in /home/ag.  I had deleted all the previous .cfg and .dat files
from earlier iterations.
-randy
At 03:21 PM 8/9/2004, Fred Dech wrote:
>i jumped the gun.  i guess that the [--configfile=CONFIGFILE] arguement is
>now required.  when i add that, to the command line everything's fine.
>--fred
>On Mon, Aug 09, 2004 at 05:04PM, Fred Dech said:
> > hi Doug.
> > i just noticed this when i started up the venue server:
> > sucag1(fdech)13% /usr/bin/python2 /usr/bin/VenueServer.py
> > bound to port  8000
> > bound to port  8006
> > Traceback (most recent call last):
> >   File "/usr/bin/VenueServer.py", line 127, in ?
> >     main()
> >   File "/usr/bin/VenueServer.py", line 89, in main
> >     venueServer = VenueServer(server, app.GetOption('configfilename'))
> >   File "/usr/bin/VenueServer.py", line 273, in __init__
> >   File "/usr/bin/VenueServer.py", line 461, in LoadPersistentVenues
> >   File "/usr/bin/VenueServer.py", line 729, in AddVenue
> >   File
> "/sandbox/agtk/dist-20040809_102253/lib/python2.3/site-packages/AccessGrid/Venue.py",
> line 379, in __init__
> >   File
> "/sandbox/agtk/dist-20040809_102253/lib/python2.3/site-packages/AccessGrid/Security/Role.py",
> line 195, in AddSubject
> > AccessGrid.Security.Subject.InvalidSubject
> > i thought it might be an imcompatibility with earlier .cfg and .dat files,
> > but i removed them and still got the same messages.
> > --fred
> > On Mon, Aug 09, 2004 at 05:55PM, Douglas Kosovic said:
> > > The Fedora Core 1 & 2 AGTk 2.3 beta1 RPMs can be found at:
> > >   http://www.itee.uq.edu.au/~agn/ag_fedora/
> > > If you were previous using yum with the AGTk CVS snaphots, then you will
> > > need to modify:
> > >     /etc/yum.conf
> > > Similarily for rhn-applet and up2date, the following file will need to be
> > > modifed:
> > >     /etc/sysconfig/rhn/sources
> > > The modifications involve changing instance of  'unstable' to 'stable'.
> > > The unstable folders will continue to contain AGTk CVS snapshots.
> > > Doug
