[AG-TECH] AGTk 2.3 BETA Released
    Fred Dech
    fdech at uchicago.edu
    Mon Aug  9 17:21:00 CDT 2004
i jumped the gun.  i guess that the [--configfile=CONFIGFILE] arguement is
now required.  when i add that, to the command line everything's fine.
--fred
On Mon, Aug 09, 2004 at 05:04PM, Fred Dech said:
> hi Doug.
> i just noticed this when i started up the venue server:
> sucag1(fdech)13% /usr/bin/python2 /usr/bin/VenueServer.py
> bound to port  8000
> bound to port  8006
> Traceback (most recent call last):
>   File "/usr/bin/VenueServer.py", line 127, in ?
>     main()
>   File "/usr/bin/VenueServer.py", line 89, in main
>     venueServer = VenueServer(server, app.GetOption('configfilename'))
>   File "/usr/bin/VenueServer.py", line 273, in __init__
>   File "/usr/bin/VenueServer.py", line 461, in LoadPersistentVenues
>   File "/usr/bin/VenueServer.py", line 729, in AddVenue
>   File "/sandbox/agtk/dist-20040809_102253/lib/python2.3/site-packages/AccessGrid/Venue.py", line 379, in __init__
>   File "/sandbox/agtk/dist-20040809_102253/lib/python2.3/site-packages/AccessGrid/Security/Role.py", line 195, in AddSubject
> AccessGrid.Security.Subject.InvalidSubject
> i thought it might be an imcompatibility with earlier .cfg and .dat files,
> but i removed them and still got the same messages.
> --fred
> On Mon, Aug 09, 2004 at 05:55PM, Douglas Kosovic said:
> > The Fedora Core 1 & 2 AGTk 2.3 beta1 RPMs can be found at:
> >   http://www.itee.uq.edu.au/~agn/ag_fedora/
> > If you were previous using yum with the AGTk CVS snaphots, then you will
> > need to modify:
> >     /etc/yum.conf
> > Similarily for rhn-applet and up2date, the following file will need to be
> > modifed:
> >     /etc/sysconfig/rhn/sources
> > The modifications involve changing instance of  'unstable' to 'stable'.
> > The unstable folders will continue to contain AGTk CVS snapshots.
> > Doug
