[AG-TECH] Problems using webcam?
    Michael Miller
    mimiller at ncsa.uiuc.edu
    Fri Aug  6 15:39:01 CDT 2004
Todd, Doug,
So I finally got the Fedora 2 kernel upgraded and the pwc module is
loaded.  I went and got Doug's updated vic from the tar file and put it in
/home/mimiller/.AccessGrid/local_services/VideoProducerService
I moved the old one out of the way of course.
However, I still get the green screen from the QuickCam.  Did I put the new
vic in the wrong place?
Michael Miller
NCSA
At 12:04 PM 7/30/2004, Todd Zimmerman wrote:
>Hi Michael,
>There were a couple of issues I had.
>The drivers are available at:
>http://www.smcc.demon.nl/webcam/release.html
>There are two parts of the driver.
>pwc: an open source driver that gives you basic functionality for the webcam
>pwcx: a binary closed source driver that gives you more resolutions and
>better functionality.
>The original release of Fedora Core 2 disabled the pwc driver in the
>kernel for some reason - but the newest kernel for FC2 has re-inserted the
>pwc module.  So, if you have an updated (including kernel) of FC2 (I'm
>currently using 2.6.6-1.435.2.3) then you should be able to modprobe pwc
>and it should just work.
>As far as pwcx, the instructions in the tar.gz download explain how to
>recompile your kernel modules and insert the pwcx module.  I just ended up
>recompiling my kernel adding the PWCX module support and now with the new
>vic from Doug, all seems good.
>There is a pwcx rpm out there... but it didn't seem to work for me.
>If you need any other help, email and I may have run across the same issue.
>Good Luck!
>Todd
>Collaboration & Visualization Technician
>WestGrid - www.westgrid.ca
>IRMACS - www.irmacs.com
>Ph. 604.268.6979
>Todd Zimmerman - toddz at sfu.ca
>Michael Miller wrote:
>>Todd,
>>I'm interested in getting the QC Pro 4000 working on FC 2.  Can you point
>>me to drivers and other needs to get this to work?
>>Michael Miller
>>NCSA
>>At 12:51 PM 7/29/2004, you wrote:
>>>I'm having a similar issue using a Logitech Pro 4000 on FC 2.  The
>>>Logitech drivers are slightly different in that you have to install the
>>>standard pwc module plus the pwcx binary kernel module to get some of
>>>the larger resolution capabilities - but I'm still getting the 'green' output.
>>>The camera works using xawtv and gnomemeeting - so I assume Vic is
>>>asking for a resolution that the driver is not capable of delivering.
>>>Any vic and/or webcam experts in the crowd??
>>>Todd
>>>Ph. 604.268.6979
>>>Benjamin Khoo wrote:
>>>>hi
>>>>i recently got a V4L supported webcam hoping to be able to get it to
>>>>work under Linux with AG.
>>>>i managed to setup the VideoProducer to obtain the device of the webcam
>>>>under /dev/video0
>>>>however, i keep getting a blank Green screen for my own video feed.
>>>>investigation for the error messages shows the following errors..
>>>>is there anything i can do to limit the dimensions of the video?
>>>>my webcam can support up to a max of 640x480, it is a Aiptek model using
>>>>the ov511 drivers. i use FC2.
>>>>thanks lots for anyone's help in advance.
>>>>14:59:32 kernel: drivers/usb/media/ov511.c: VIDIOCMCAPTURE: requested
>>>>dimensions too big
>>>>15:20:54 kernel: drivers/usb/media/ov511.c: VIDIOCMCAPTURE: requested
>>>>dimensions too big
>>>>15:22:25 kernel: drivers/usb/media/ov511.c: VIDIOCMCAPTURE: requested
>>>>dimensions too big
>>Thanx,
>>Michael Miller
>>System Engineer
>>Visualization Technology Support
>>Computing and Data Management
>>National Center for Supercomputing Applications
>>University of Illinois - UC
>>217-649-0747
>>"If you're clear in your vision and trust the people in your team with
>>clear objectives, they will invariably do their best to achieve
>>everything desired, and usually deliver everything you could have hoped
>>for and even more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
