[AG-TECH] Osprey-100 and WinXP Access Grid Toolkit 2.2
    Michael Miller
    mimiller at ncsa.uiuc.edu
    Thu Aug  5 10:11:36 CDT 2004
Fred,
I figured out the solution and am posting it to the email list so I can
find it later.  To stop vic from asking for the rtpName and rtpEmail put
this in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\vic\vic\rtpName="..."
HKEY_LOCAL_MACHINE\SOFTWARE\vic\vic\rtpEmail="..."
With the ... replaced with the appropriate values.  It appears this is not
necessary on all machines.  I think it has something to do with whether you
install as the Administrator or not.
HTH
Michael Miller
NCSA
At 10:13 AM 6/23/2004, Fred Dech wrote:
>... i also then need to re-submit my VIC rtpEmail info,
>not once, not twice, but three times.  ouch.  this is not usable at this
>point.
>--fred
>On Wed, Jun 23, 2004 at 09:37AM, Chris Rosenthal said:
> > Yes.  I know that that's available.  That's a real pain to have to do each
> > time you change venues, though.  Also, I kept getting errors when doing it
> > that way.  So, I just dropped back to 2.1.2 and everything seems good in
> > that respect.
> > Maybe 2.2.1 will take care of this.
> > Chris
> > Chris Rosenthal                               cmr at evl.uic.edu
> > Electronic Visualization Lab                  (312) 996-3002
> > University of Illinois at Chicago
> > On Tue, 22 Jun 2004, Fred Dech wrote:
> > > i just stumbled through this.
> > > WinXP.  add your VideoProducerService for each capture card, then
> you'll have
> > > some blank 1 Real Vic and 1 or more blank Vics.  for each blank Vic,
> select
> > > 'Menu' at the bottom, and the 'Devices' drop-down should display all
> of your
> > > Ospreys.  select a different one for each Vic.
> > > hope that helps.
> > > --fred
> > > On Tue, Jun 22, 2004 at 09:03AM, Duncan Waddell said:
> > > > Hi learned folks,
> > > > Add my name to the list too.  I also have an urgent need to get an
> > > > Osprey-100 card working with AGT 2.2 (WinXP).
> > > > Duncan
> > > > A Quay wrote:
> > > > >I have the exact same problem. In a week I have to visit a college in
> > > > >Miami to install an AG node and really need help on getting four
> Osprey
> > > > >100???s working on a WinXP box.
> > > > >Andy Quay
> > > > >Associate Director
> > > > >Digital Worlds Institute, University of Florida
> > > > >-----Original Message-----
> > > > >*From:* Chris Rosenthal [mailto:cmr at evl.uic.edu]
> > > > >*Sent:* Friday, June 18, 2004 3:11 PM
> > > > >*To:* ag-tech at mcs.anl.gov
> > > > >*Subject:* [AG-TECH] Video Producer Config Help
> > > > >Hello,
> > > > >I know there???s been a lot of talk about configuring video capture
> > > > >devices in Linux.  I???ve got four Osprey 100???s on a WinXP node
> and the
> > > > >Video Producer Services always default to the same capture card on
> AGT
> > > > >2.2.  There doesn???t seem to be the same options for configuring the
> > > > >sources from the node management dialog (as previous versions).  Am I
> > > > >supposed to enter something in the port text box?  Is there a
> patch out
> > > > >or coming out soon that makes this easier?
> > > > >I will really appreciate your help in taking care of this problem.
> > > > Duncan Waddell  (BSc)
> > > > Principal Scientific Officer
> > > > Centre for Microscopy and Microanalysis
> > > > The University of Queensland.   St. Lucia.  Qld.  4072
> > > > Telephone:      +61-7-3365-4216
> > > > Facsimile:      +61-7-3365-1775
> > > > WWW:            http://www.uq.edu.au/nanoworld/nanohome.html
> > > >        Any opinion expressed is that of the writer,
> > > >    and not necessarily that of CMM or of the University.
> > >   Fred Dech   fdech at uchicago.edu
> > >   University of Chicago Dept. of Surgery
> > >   Ph: (773) 834-8359, Fax: (773) 834-8140
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
