[AG-TECH] AccessGrid on a bootable live cd (Knoppix) : certificate question
Joseph
joseph at cs.usyd.edu.au
Wed Aug 4 00:30:26 CDT 2004
Hi
<snip>
> We should look at the log files (or debug output) to understand why it's
> failing to use the certificate.
Here is a debug output (joined to this mail), I hope it will help you ! I
have commented it a little bit.
BTW, the content of the error message is :
Private key is not available for this certificate :
/O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=<snip>/CN=<snip>
You will have to reimport or otherwise obtain a new copy.
(What did I do ? I have copied an existing /home/user/.AccessGrid folder,
of an user with a valid certificate, into the /home/user/.AccessGrid of my
iso, before burning it. Then after burning, I have launched VenueClient.py
--personalNode).
<snip>
> Do multiple users log in, or just one? If there is a generic user, you
> should be able to create a .AccessGrid directory for that user with an
> anonymous certificate (we issue these now), and have everything work
> fine.
The trouble is that anonymous certificates prevent often from connecting
to some Venue, like the Asian Pacific one for example. So it's exactly
appropriate.
Thanks all for your help
Cheers,
Joseph
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040804/e0244c73/attachment.obj>
