[AG-TECH] Mac OS X Progress, RAT is being stuborn
grzesiek at mi2.hr
grzesiek at mi2.hr
Mon Aug 2 16:03:20 CDT 2004
Have a look on www.openmash.org.
OpenMash is already running on osx however its using vat for audio (less codecs and different sampling frequencies)
Grzesiek
On Sun, Aug 01, 2004 at 08:25:30PM -0400, Jerome wrote:
> So I managed to treck thru hacking at VIC to compile under OS X
> 10.3.4, wasn't bad just header files with different paths...
> haven't found much on OS X AG stuff besides hearing that there's a beta...
> but i've been working on installing the various components for AGTk
> 2.2, Globus, PyGlobus, and other modules are all installed, but I'm
> stuck at one thing that keeps me from continuing to explore...
> gcc -g -O2 -W -Wall -Wbad-function-cast -Wmissing-prototypes
> channel.o channel_types.o cc_vanilla.o cc_rdncy.o cc_layered.o
> render_3D.o repair.o ts.o playout.o net.o source.o session.o
> main_engine.o mbus_engine.o audio.o cushion.o mix.o parameters.o
> transmit.o playout_calc.o ui_send_rtp.o ui_send_audio.o
> ui_send_prefs.o ui_send_stats.o transcoder.o rtp_dump.o rtp_callback.o
> settings.o pdb.o pktbuf.o tonegen.o voxlet.o fatal_error.o
> libuclaudio.a libuclcodec.a libuclsndfile.a
> -L/Users/jerome/PythonProjects/AccessGrid/ag-media/common/src
> -luclmmbase -lm -o rat-4.2.22-media
> ld: Undefined symbols:
> _rtp_get_ssrc_count
> it looks to me this symbol is defined in the UCL MM library,
> ../common/src/libuclmmbase.a
> but attempting to try various other methods to linking it still ends
> up with undefined symbol
> anybody got suggestions? much appreciated
