[AG-TECH] An onslaught of questions
Randy Groves
randy.groves at boeing.com
Fri Apr 23 10:23:24 CDT 2004
If you are using AG2, might I make a suggestion? Create a node setup that
is audio only (you could even make this your default), in addition to your
normal setup. Use the audio-only setup to navigate to your chosen
venue. Then change to your normal setup. That way you avoid the video
streams on the way in.
-randy
At 07:53 AM 4/23/2004, Steve Gallo wrote:
> > Ron Crummett wrote:
> > >-My boss and I think that the bandwidth is the key issue here. 25
> video streams, all transmitted at a rate near 100
> > kb/s...that's a total around 2.5 Mb/s, just under the capability of two
> T1s. Is this an accurate estimate of the
> > per-stream video bandwidth (100 kb/s)?
> > The minimum connection is 100Mb/s.
>We have been in conferences with sites that have only a T1. They can't
>support
>25 streams, but we did make adjustments to make things workable for small
>numbers
>of streams. My guess is that you can get by with much less than 100 Mb/s,
>more
>like 15 Mb/s.
>Steve
