[AG-TECH] shared browser with private website possible?
    ivo schindler
    ag-techliste at toastbrot.ch
    Thu Apr 15 05:22:44 CDT 2004
don't you need to hand out passords as well? of course one could
generate sessionpasswords, but it is still to complicated. Compared to
all the proposed solutions it is much less difficult to use microsoft
netmeeting to share secured websites. i think this is a pity and i don't
want to propose netmeeting. it lacks a lot of usefull stuff that AG provides.
maybe an extended pictureviewer, where one could grab the actual screen
and refresh it every second would already almost solve this problem...
it wont be very elegant. but more comfortable than the other solutions
(hardware, vnc, proxy)
is there anything planned for sharing for example a secured website or a
local window for an upcoming release of AG or by some independent developer?
thanx again and greetings.ivo
On Wed, Apr 14, 2004 at 08:11:10AM -0500, Ivan R. Judson wrote:
> The other alternative is to use the shared browser with a shared proxy; this
> changes the application structure slightly, but makes it much more like the
> trivial shared applications that have been done for decades, simply
> multiplexing input and output.
> We did a shared adventure back in '93 that way that was a smash hit :-)
> --Ivan
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov
> > [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of ivo schindler
> > Sent: Wednesday, April 14, 2004 2:57 AM
> > To: Hank Magnuski
> > Cc: ag-tech at mcs.anl.gov
> > Subject: Re: [AG-TECH] shared browser with private website possible?
> > Hi Hank
> > Thank you for your answer, it was the only one!
> > you are right in the points of security and so on. but
> > hardware is out of scope of my thesis and it would use 2
> > computer for every node plus your hardware. as i would use AG
> > for a big amount of Workingspaces i think your proposed
> > solution is not realistic.
> > do you or anybody else know any other solution? i've tested
> > vnc but this is neither integrated in ag nor does it scale at all.
> > thank you and greetings.
> > ivo schindler
> > On Thu, Apr 08, 2004 at 07:30:13AM -0700, Hank Magnuski wrote:
> > > On Thu, 8 Apr 2004, ivo schindler wrote:
> > > > hi all
> > > > i want to share a private website (secured by htpasswd or
> > even one
> > > > in a private subnet). how can i manage that, without giving the
> > > > login- informations to the others? Is that possbile at all?
> > > Yes. We offer an alternative solution to solve this problem
> > which is
> > > more secure and easier to use than the various software solutions
> > > currently available.
> > > Take a look at this product:
> > >   http://www.ncast.com/telepresenterG2.htm
> > > It captures the analog RGB signals from the output of a PC (in your
> > > case, the secure PC logged into the private subnet showing the
> > > internal page) and then packetizes and multicasts this image as a
> > > high-resolution MPEG-4 multicast (1024x768 at 8 frames/sec).
> > > Thus, ANYTHING shown on the desktop of the PC will be captured and
> > > broadcast to the other nodes (web pages, Powerpoints, Excel, custom
> > > software, etc.).
> > > The security of the internal network is assured because the link
> > > between the internal and external networks is an RGB cable
> > which acts
> > > as a natural and complete firewall.
> > > Any of the other solutions require the presentation PC to be on the
> > > external network (the Access Grid nodes) and the internal network
> > > (private
> > > subnet) simultaneously, allowing for potential security faults.
> > > If you have any questions about this, or if you would like to see a
> > > demo of this for your government project, please let me know.
> > > Hank
      _   __                                           _   __
     ( `^` )) ivo  schindler  mr.shintla at toastbrot.ch ( `^` ))
     |     || seestrasse 297  http://www.toastbrot.ch |     ||
     |     || CH-8038 zurich  tel ++41 (0)1 481 37 91 |     ||
pgp/gpg key: 1024D/202E5DC6 or get it from: http://pgp.toastbrot.ch/
key fingerprint : BD6A B471 54DB 30C3 25E2  07D6 93E6 6A6E 202E 5DC6
