[AG-TECH] AG2 dies because of Life in Hours
    Supreeya Miller
    Supreeya.Miller at usm.edu
    Tue Apr 13 10:51:54 CDT 2004
Michael,
Thank you for the direction.
However....
I did not have to Ctrl-c or do anything to arm- and vrm-eventlisterner.
They always ran gracefully and reliably.
Supreeya Miller
Visualization Researcher, System Administrator, and Access Grid Coordinator
Center of Higher Learning
Building 1103
Stennis Space Center, MS  39529
228-688-2190
Internal Mail Box: 10002
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
Behalf Of Michael Miller
Sent: Tuesday, April 13, 2004 9:32 AM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] AG2 dies because of Life in Hours
Supreeya,
We've seen that here at NCSA as well.  The workaround is to CTRL-C the
AGServiceManager.py process before the proxy expires.  We do this after
each AG meeting, similar to what we did with arm-eventlistener and
vrm-eventlistener way back in the AG1 days... ;-)
There are Bugs #896 and #793 reported on this issue.
Michael Miller
NCSA
At 09:56 AM 4/13/2004, Supreeya Miller wrote:
>All,
>When I ran AGServiceManager.py on the audio machine running Redhat 9.0, it
>asked the passphrase.  I gave it the password when I requested the
>certificate.  Then it asked me Life in hours [12]:, I hit enter.  Sure
>enough it died the next day.
>When this happened, and I went to a different room from the display
machine,
>I did not get a new vic window of the new room, and the vic of the old room
>stayed unchanged.
>1) I went to check things on the audio machine, it said a system call
>failed.  I tried to re-run the AGServiceManager.py again, and it would not
>run until I killed the AudioService.py.
>2) I had to do a similar process on the video machine in order to run
>AGServiceManager.py.
>3) Again on the display machine, I had to kill the AGServiceManager.py
>program and re-ran it.
>Now everything was back to normal.
>The next day it died again.  Then I had to repeat the 3 steps above.
>Does this have something to do with the question "Life in hours[12]"?  If
>so, how do I get around it so that the AG will run all a time?
>If not, can you please guide me to a solution to my problem?
>Thank you.
>Supreeya Miller
>Building 1103
>228-688-2190
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
