[AG-TECH] AG2 dies because of Life in Hours
Supreeya Miller
Supreeya.Miller at usm.edu
Tue Apr 13 09:56:51 CDT 2004
All,
When I ran AGServiceManager.py on the audio machine running Redhat 9.0, it
asked the passphrase. I gave it the password when I requested the
certificate. Then it asked me Life in hours [12]:, I hit enter. Sure
enough it died the next day.
When this happened, and I went to a different room from the display machine,
I did not get a new vic window of the new room, and the vic of the old room
stayed unchanged.
1) I went to check things on the audio machine, it said a system call
failed. I tried to re-run the AGServiceManager.py again, and it would not
run until I killed the AudioService.py.
2) I had to do a similar process on the video machine in order to run
AGServiceManager.py.
3) Again on the display machine, I had to kill the AGServiceManager.py
program and re-ran it.
Now everything was back to normal.
The next day it died again. Then I had to repeat the 3 steps above.
Does this have something to do with the question "Life in hours[12]"? If
so, how do I get around it so that the AG will run all a time?
If not, can you please guide me to a solution to my problem?
Thank you.
Supreeya Miller
Visualization Researcher, System Administrator, and Access Grid Coordinator
Center of Higher Learning
Building 1103
Stennis Space Center, MS 39529
228-688-2190
Internal Mail Box: 10002
