[AG-TECH] New Shared Image tool
    Jennifer Teig von Hoffman
    jtvh at bu.edu
    Mon Apr 12 15:24:11 CDT 2004
I'm having a little trouble too. I copied over the file and it didn't
work (the old version still ran, not the new one), and then when I tried
to re-install (using the -f option) I got this:
Couldn't copy file into place (undoing register).
App directory error -- can't remove (C:\Documents and
Settings\jtvh\Application
Data\AccessGrid\SharedApplications\Basic_Image).
And now I can't run Basic Image at all.
Anybody seen this and found a way around it? Do I need to somehow
un-install and start from scratch?
- Jennifer
George Estes wrote:
>   Don't know why but just coping the file did not work for me.  I had to go through the install process and it worked.   Anyway, pretty cool but it needs an undo command.
> George
> At 10:18 AM 4/12/2004 -0500, you wrote:
>>X-Envelope-From: semeraro at ncsa.uiuc.edu
>>X-Envelope-To: <ag-tech at mcs.anl.gov>
>>X-Sender: semeraro at mail.ncsa.uiuc.edu (Unverified)
>>X-Mailer: QUALCOMM Windows Eudora Version 5.1
>>Date: Mon, 12 Apr 2004 10:18:40 -0500
>>To: ag-tech at mcs.anl.gov
>>From: Dave Semeraro <semeraro at ncsa.uiuc.edu>
>>Subject: [AG-TECH] New Shared Image tool
>>X-Spam-Status: No, hits=0.0 required=5.0
>>       tests=none
>>       version=2.55
>>X-Spam-Level:
>>X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
>>Sender: owner-ag-tech at mcs.anl.gov
>>X-Deliver-To: gestes
>>X-MD5SUM: a6100c44149c7bd740c8dea5b3b15891
>>Hello folks,
>>I finally finished adding markup capability to the shared image viewer. That means that once
>>an image is loaded you can use the mouse and left mouse button to draw on the image
>>with a pen. Click the left mouse button and hold it down while you draw on the image. When
>>you release the left button the coordinates of what you drew are uploaded to the venue and
>>all the other image viewers are updated. You will just see the image change to include the
>>marks made by the user. The marks do not show up incrementally. Hey it was the easiest
>>implementation.
>>I also added the capability to change pen color. This is handy when others are marking on
