[AG-TECH] Soundblaster Live! input routed to output?
    Dwight D.McKay
    mckay at purdue.edu
    Wed Apr  7 12:51:23 CDT 2004
Mike,
That's sounds like what I'd like to disable, but alsamixer shows no
"Analog Loopback" for any of the sliders, all the way across...
On Apr 7, 2004, at 12:24 PM, Michael Miller wrote:
> Dwight,
> I just wanted to check that you did open alsamixer and mute the
> "Analog Loopback" setting.  The mixer doesn't always show you all the
> sliders at once.  Make sure you move to the right as far as you can
> go.  That's where I found the loopback setting for my cirrus based
> card.
> Michael Miller
> NCSA
> At 12:10 PM 4/7/2004, Dwight D.McKay wrote:
>> Folks,
>> We're experiencing a strange problem with a new room node. The audio
>> machine is using a new, soundblaster live! card that seems to route
>> the analog line input to the analog line output no matter what we do.
>> We've tried both the RedHat 9 sounds drivers and ALSA.
>> On an earlier model Soundblaster (128?), we needed to use emu-dspmgr
>> and change the routing on the card to avoid this problem. On this
>> card, the similar routing trick doesn't seem to work.
>> Has anyone seen this and found a solution?
>>   Dwight D. McKay, Technical Architect
>>   Envision Center for Data Perceptualization, Office of the VP for
>> IT, Purdue University
>>   mckay at purdue.edu / 765.494.4481 [VOICE] / 765.496.7264 [FAX] / STEW
>> B31
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have
> hoped for and even more." -Paul Debevec
   Envision Center for Data Perceptualization, Office of the VP for IT,
Purdue University
B31
