[AG-TECH] CVS assistance - I'd LIKE to be able to check out the new stuff
Randy Groves
randy.groves at boeing.com
Wed Apr 7 13:15:23 CDT 2004
OK - I'm having a problem with the CVS (this is on RH9).
I've installed the binaries for wxPython, vic and rat from the 2.1.2 release.
I've grabbed the latest, and following the README-developer notes (which
are in need of revision), I made the 'cfg' directory, and ran:
python AccessGrid/tools/CvsSetup.py --agdir AccessGrid --dst cfg
(note the change - in the doc it's in 'bin')
This was done as root.
Then I logged in as my ag user and tried to run the VenueClient:
/usr/bin/VenueClient.py --personalNode
I get the following error:
Traceback (most recent call last):
File "./VenueClient.py", line 38, in ?
from AccessGrid.Toolkit import WXGUIApplication
File "/usr/local/src/ag/ag-cvs/AccessGrid/AccessGrid/Toolkit.py", line
18, in
from optparse import OptionParser, Option
ImportError: No module named optparse
I've done some poking around, and so far, I don't see any mention of this
module. Is there a step that I'm missing? Should I be loading a different
wxPython from CVS?
I know you folks are busy, but I'd like to be able to check this out and
give what assistance I can.
Thanks!!
-randy
